1 - 20 of 129 Posts
Trailer and trunk lid
When my trailer is connected, mytrunk lid doesn't open, it unlocks but I have to hold the button and lift it manually up.
On my old Audi Q5 the lid did open with power if I touched the lid switch from outside.
I quickly went through the convenience, central elect etc but didn't find anything refering to the lid and trailer.
Anyone....?
It's by design so you don't damage the hatch should it open into the trailer.
My previous was Audi Q5 and the trunk lid protection with trailer worked the way user had to touch the lid outside switch (not the drivers door switch), first touch released the lid to "half locked stage" (or how ever it's called when the door is not fully sealed but it doesn't open either) and second touch used the power opening.
Is this manual opening NA feature to prevent the law suits or is this also in Europe and Australia?
It has the same behaviour in Australia.
IMHO the whole power tailgate logic is rather poorly thought out. Why?
  • Most trailers, like mine, will not obstruct the tailgate. In fact having a trailer connected prevents other objects getting in the tailgate's path. There's no way to enable it with a tailer connected.
  • The tailgate will happily crunch into a bike carrier, garage door, wall etc. There's no way to disable it in these situations.
  • The tailgate can be accidentally opened remotely (from a great distance) creating a risk of theft or damage. There's no way to prevent this.
VW have managed to turn a convenient accessory into a liability.
One solution would be to have a "Enable | Disable | Auto" setting for remote control of the tailgate.
I'm guessing that after the novelty of "door goes up, door goes down, door goes up..." wears off, most people would disable it.
c4ar,
Yep my trailer is not on the lids way and the previous Audi Q5 did power open and close with trailer so I would like to have Touareg to do same..
I found the adaptation and it seems to have something to do with lid control BUT I need the security code kaboom
shows the option but doesn't allow to change until security code is entered.
The common 20113 doesn't work...
Anyone....?
W O O O O H O O O O O O :dance: :dance: :dance:
Thank you ROSS-TECH!!!!
I wrote email to them and asked the security access code and I got email...
I logged on and activated the opening and now my trunk have POWER opening and closing when trailer is connected.
I tried the lid switch so I'm not sure about the drivers door, I have to test it tomorrow.
Anyways, at least the trunk lid switch works!
Security access is 12345.
I also changed the pre-latch to main-latch and I have to test and change it back to "pre" to see if it makes any difference....
Discussion Starter #8
Bright front LED for light switch parking lights position with >< sign
(normal park position LED's are half from DRL brightness):
Change X to 1
Central Elect -> Byte 3: 3rd digit: 00000X00
(the zero's doesn't mean everyone haves zero, it's just to show the 3rd digit to change)
I had it on my Q5 and then thought to try and behold... this keeps the brightness on same level as on DRL's (I saw on Russian forum that there is way to control the actual brightness but that's something I have no desire to play with)
Discussion Starter #9
Another test...
The pre-latch and main-latch does seem to make difference so I turned it back to pre-latch.
Also checked the drivers door lid button and it power opens and closes the lid when trailer is connected.
Discussion Starter #10
Enabling passenger mirror tilt down on cars without memory seats,
- mirror adjusting knob on R (on lefthand drive cars)
- shifter on R
Mirror turns back to original position once forward speed exceeds few mph and it stays tilted if vehicle doesn't move.
Change A and B to 1.
52 Door Elect, Pass.
Long coding, Byte 4 -> Bits 2 and 6: 0B000A00
I was reading old codes from previous Q5 and saw the mirror thingie and thought to try does the passenger mirror turn down, it didn't so I tried the coding and now it works on mine.
Discussion Starter #12
European and rest of ROW T3 owners, please post or PM me your vag-com scan so I could compare the ROW coding to NA coding.
I saw post here where one member is trying to find away to activate the tail amber blinkers and while I changed my tail light bulbs to LED's, I noticed there is own reflector and bulb base for separate blinker (not brakelight blinker).
I have to go check it again to see if there is even wire going to the blinker base and all it would need is the vag-com coding to get the power...
Good Evening,
i'm from Germany owning a T3 from 2011. There it comes:
Fahrzeugtyp: 7P6
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 6C 72
Fahrzeug-Ident.-Nr.: WVGZZZ7PZCD00xxxx
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: Fehler 0010
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
5F-Informationselek. I -- Status: Fehler 0010
62-Türelektr. hi. li. -- Status: i.O. 0000
6C-Rückfahrkamera -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CJMA) Labeldatei: Keine
Teilenummer SW: 7P0 907 311 C HW: 4G0 907 401
Bauteil: 3.0TDI EDC17 H37 0002
Revision: 53H37---
Codierung: 292A4012232601020000
Betriebsnr.: WSC 31414 790 00001
ASAM Datensatz: EV_ECM30TDI0117P0907311C 001002
ROD: EV_ECM30TDI0117P0907311C.rod
VCID: 2F66600B76066CC
1 Fehler gefunden:
14690 - Verlademodus aktiv
P169A 00 [032] - -
Sporadisch - unbestätigt - geprüft seit letzter Löschung
Freeze Frame:
Fehlerstatus: 00100000
Fehlerpriorität: 0
Fehlerhäufigkeit: 0
Verlernzähler: 0
Kilometerstand: 0 km
Datum: 2000.00.00
Zeit: 00:00:00
Readiness: 0 0 0 0 0
Adresse 02: Getriebe (J217) Labeldatei: 0C8-927-750.clb
Teilenummer SW: 0C8 927 750 AM HW: 0C8 927 750 AM
Bauteil: AL1000 AISIN 001 1932
Seriennummer:
Codierung: 001568
ASAM Datensatz: EV_TCMAL991031 002112
ROD: EV_TCMAL991031.rod
VCID: 77F6986BCED664C
Kein(e) Fehlercode(s) gefunden.
Adresse 03: Bremsenelektronik (J104) Labeldatei: 7P0-907-379.clb
Teilenummer SW: 7P0 907 379 K HW: 7P0 907 379 A
Bauteil: MK25A H36 0418
Revision: -------- Seriennummer: 413610010EC010
Codierung: 5B6B13C309242554DAF8C89790D9A4507700
ASAM Datensatz: EV_MK25AXT 007001
ROD: EV_MK25AXT.rod
VCID: 458A22A3C4BAC6C
Adresse 05: Zugangs-/Startber. (J393) Labeldatei: DRV\8K0-907-064-05.clb
Teilenummer SW: 4H0 907 064 BL HW: 4H0 907 064 BL
Bauteil: BCM2 2.0 H31 0330
Revision: 00002001
Codierung: 01A60000000000000000
VCID: 74ECAF67D7A00F4
Subsystem 1 - Teilenummer SW: 7P6 959 754 AA HW: 7P6 959 754 AA
Bauteil: FBSTOUAREGIDG H05 0051
Subsystem 2 - Teilenummer SW: 4H0 905 852 B HW: 4H0 905 852 B
Bauteil: J764 ELV MLB H38 0044
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: Keine
Teilenummer SW: 7P6 907 040 BA HW: 7P6 907 040 BA
Bauteil: Klima 2 Zonen H20 1203
Codierung: B606000A90
ASAM Datensatz: EV_AirCondiFront 004001
VCID: 74ECAF67DFA00F4
1 Fehler gefunden:
0247 - Funktionseinschränkung durch empfangenen Fehlerwert
U1113 00 [008] - -
Sporadisch - bestätigt - geprüft seit letzter Löschung
Freeze Frame:
Fehlerstatus: 00000001
Fehlerpriorität: 6
Fehlerhäufigkeit: 5
Verlernzähler: 213
Kilometerstand: 10984 km
Datum: 2011.12.22
Zeit: 20:25:46
Adresse 09: Zentralelektrik (J519) Labeldatei: 4H0-907-063.clb
Teilenummer SW: 4H0 907 063 L HW: 4H0 907 063 D
Bauteil: BCM1 2.0 H12 0092
Revision: 15012002 Seriennummer: 00000001072580
Codierung: 26001011D1345D010021000300005D0C431C470806010241000000020000
VCID: 3162667368327AC
Subsystem 1 - Teilenummer SW: 7P0 955 119 HW: 7P0 955 119 Labeldatei: DRV\1KX-955-119.CLB
Bauteil: WWS 110518 31 0020
Codierung: 004DBD
Subsystem 2 - Teilenummer SW: 7P0 955 559 D HW: 7P0 955 559 D Labeldatei: DRV\8K0-955-559.CLB
Bauteil: RLFS H09 0011
Codierung: 025223
Subsystem 3 - Teilenummer SW: 7P6 941 431 D HW: 7P6 941 431 D
Bauteil: E1 - LDS H04 0031
Adresse 10: Einparkhilfe 2 (J446) Labeldatei: 7P6-919-475.clb
Teilenummer SW: 7P6 919 475 B HW: 7N0 919 475
Bauteil: PARKHILFE 8K H05 0021
Revision: -------- Seriennummer: 28291109465968
Codierung: 308501
ASAM Datensatz: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 428039BFD594F14
Adresse 15: Airbag (J234) Labeldatei: 5K0-959-655.clb
Teilenummer SW: 7P0 959 655 B HW: 7P0 959 655 B
Bauteil: VW10Airbag001 H05 0023
Revision: -------- Seriennummer: 003JX002UHT4
Codierung: 000000000000000000000000000000003031
ASAM Datensatz: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526.rod
VCID: 408433B7DB98E34
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 3575LRB40590HJHG8P1S
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 3585LRB40650HJHGEP0V
Crashsensor für Seitenairbag hinten Fahrerseite:
Seriennummer: 3515RRB404R0JE3G28TX
Crashsensor für Seitenairbag hinten Beifahrerseite:
Seriennummer: 3525RRB404R0JE3G7OVE
Crashsensor für Frontairbag Fahrerseite:
Seriennummer: 3555NRB405T0HM7ENHCE
Crashsensor für Frontairbag Beifahrerseite:
Seriennummer: 3565NRB405T0HM7EMP2C
Adresse 16: Lenkradelektronik (J527) Labeldatei: Keine
Teilenummer SW: 4H0 953 568 A HW: 7P6 953 507
Bauteil: Lenks.Modul H08 0007
Revision: -------- Seriennummer: 90815KEK00040
Codierung: 000015
Subsystem 1 - Teilenummer SW: 7P6 959 542 HW: 7P6 959 542
Bauteil: E221__MFL-TAS H03 0027
Adresse 17: Schalttafeleinsatz (J285) Labeldatei: 7P6-920-xxx-17.clb
Teilenummer SW: 7P6 920 880 P HW: 7P6 920 880 P
Bauteil: Kombi H13 0239
Revision: 11240062 Seriennummer: 658310511593038
Codierung: 133731002A000008000004
ASAM Datensatz: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 48942B97F3A8DB4
Adresse 19: Diagnoseinterface (J533) Labeldatei: Keine
Teilenummer SW: 7P6 907 530 C HW: 7P6 907 530 A
Bauteil: GW-CAN-L-MOST H08 5202
Revision: -------- Seriennummer: 00000000162461
Codierung: 000D077500
ASAM Datensatz: EV_GatewVW526UDS 001006
ROD: EV_GatewVW526UDS.rod
VCID: 38745B578348AB4
Steuergerät für Batterieüberwachung:
Subsystem 1 - Teilenummer SW: 7P0 915 181 A HW: 7P0 915 181
Bauteil: Batt_Sensor H07 0140
Seriennummer: 00000000005650555642
Spannungsstabilisator:
Adresse 36: Sitzverst. Fahr. (J136) Labeldatei: Keine
Teilenummer SW: 4H0 959 760 D HW: 4H0 959 760 D
Bauteil: MEM-FS H08 0153
Revision: AA000000 Seriennummer: 00000006135993
Codierung: 0058130000004001000001010101202020202121202020
VCID: 346C6F6797204F4
Adresse 42: Türelektr. Fahrer (J386) Labeldatei: Keine
Teilenummer SW: 4H0 959 793 F HW: 4H0 959 793 F
Bauteil: TSG FA H07 0162
Revision: -------- Seriennummer: 0000116694839
Codierung: 011D0620DE00451005080000
VCID: 3C7C4747BF70874
Adresse 46: Komfortsystem (J393) Labeldatei: 4H0-907-064-46.clb
Revision: 00002001 Seriennummer: 0150938039
Codierung: 0100162028B9008083200624000000000000000000000000000000000000
Adresse 47: Soundsystem (J525) Labeldatei: Keine
Teilenummer SW: 7P6 035 466 HW: 7P6 035 466
Bauteil: DSP Prem H01 0090
Revision: 00001001 Seriennummer: 10811000638502
VCID: F5EA12635CDA96C
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei: Keine
Teilenummer SW: 4H0 959 792 F HW: 4H0 959 792 F
Bauteil: TSG BF H07 0162
Revision: -------- Seriennummer: 0000116638989
VCID: 3B7E445BBA7E80C
Adresse 53: Feststellbremse (J540-) Labeldatei: 7P0-907-801.clb
Teilenummer SW: 7P0 907 801 F HW: 7P0 907 801 F
Bauteil: EPB H51 1201
Revision: 00000000 Seriennummer: A11519006EC
Codierung: 01040100
ASAM Datensatz: EV_ParkbA7 000006
ROD: EV_ParkbA7.rod
VCID: 3668556F895C5D4
Adresse 55: Leuchtweitenreg. (J745) Labeldatei: Keine
Teilenummer SW: 7P6 907 357 HW: 7L6 907 357 C
Bauteil: AFS-ECU H04 0110
Revision: -------- Seriennummer: --------------
Codierung: 018A00000F000200
ASAM Datensatz: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS.rod
VCID: FCFC074777F0C74
Adresse 56: Radio ® Labeldatei: DRV\4F0-035-0xx-56.clb
Teilenummer SW: 4G0 035 061 G HW: 4G0 035 061
Bauteil: Radio U DAB H52 0097
Revision: AB001007 Seriennummer: 109EO0B7522510
Codierung: 010105010000000003
VCID: 2142963338D2CAC
Adresse 5F: Informationselek. I (J794) Labeldatei: DRV\4E0-035-6xx-5F.clb
Teilenummer SW: 7P6 035 670 B HW: 7P6 035 670 B
Bauteil: H-BNT-EU H45 0203
Revision: -------- Seriennummer: 478HA0B7546855
Codierung: 020100050040C1EF41000B0E00000003F0040101
Betriebsnr.: WSC 44407 142 104002
Subsystem 1 - Teilenummer: 8R0 060 884 N
Bauteil: EUR 2011 1205
Subsystem 2 - Teilenummer SW: 7P6 919 603 HW: 7P6 919 603
Bauteil: DU8 SV Touch H24 0045
Subsystem 3 - Teilenummer SW: 7P6 919 603 HW: 7P6 919 603
Subsystem 4 - Teilenummer: 8R0 060 961
Bauteil: CD-Database 1886
1 Fehler gefunden:
03276 - Softwareversionsmanagement prüfen
000 - -
Freeze Frame:
Fehlerstatus: 01100000
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 155
Kilometerstand: 10423 km
Zeitangabe: 0
Datum: 2011.12.05
Zeit: 14:34:43
Freeze Frame:
Text: MuGPS,Main,M,0,0,6
Adresse 62: Türelektr. hi. li. (J388) Labeldatei: Keine
Teilenummer SW: 4H0 959 795 B HW: 4H0 959 795 B
Bauteil: TSG HL H09 0162
Revision: -------- Seriennummer: 0000116652677
Codierung: 011C06200000251005080000
VCID: 3A70415FB544B94
Adresse 6C: Rückfahrkamera Labeldatei: DRV\4L0-910-441.lbl
Teilenummer SW: 7P6 907 441 A HW: 4H0 907 441
Bauteil: SG Rueckfahrkamera 0020
Revision: 00H04000 Seriennummer: 525 PA8J131029
Codierung: 0020001
VCID: 3776586B4656A4C
Adresse 72: Türelektr. hi. re. (J389) Labeldatei: Keine
Bauteil: TSG HR H09 0162
Revision: -------- Seriennummer: 0000116651944
Ende --------------------------------------------------------------------
Hope it will help you.
CU
Zed
Administrator
So it looks like coding for German models is:
Seriennummer:
Codierung: 001568
Quite different from the T1/T2 codes, how does it compare to T3s over here?
Discussion Starter #15
2012 North America T3 TDI
Zed,
Is yours 4Motion or 4XMotion and does yours show the gear number next to D and S?
- shifter on R
hi,
what means "Change A and B to "1" ??
I can't try this for myself, because within the seat-memory-function the passenger mirror tilts down automatically.
Somone tried this and reportet, that the mirror doesn't turn back to the original position.
CU
Zed
Discussion Starter #18
....Byte: 0 0 0 0 0 0 0 0
Position: 7 6 5 4 3 2 1 0
B is 6th byte and A is 2nd byte.
I used alphabets to indicate the byte as using number could confuse as well.
On vehicle without memory seats, change the 6th and 2nd (B&A) byte to 1
On mine, mirror does not return to normal position while vehicle is standing still where it was reversed at. Once vehicle moves forward the mirror will return to its normal position.
Car's with memory seats should have this feature activated already.
Hi, I am experiencing this problem, before the tow hitch was installed, the side mirrors folds when you lock it, not after the installation, won't work..... pls help, Thanks in advance
1 - 20 of 129 Posts
