Well I finished up with the transmission fluid service, but I ran into a major snafu. Two of the pan bolts broke off while removing the pan. The first happened much quicker than I expected, so I took my time (45 minutes) on the second one. I was able to back it out from "full tight" about five revolutions after working on it in and out and squirting PB Blaster into it at least 15 times. Once I realized that the bolt wasn't even 1/4 way out, I lost patience and ramped up the torque, and sure enough, snap. I pulled out my bolt removal kit and started drilling into the first broken bolt. It didn't take long for that bit to break off inside the bolt (major ugh), so now I was really pissed and went into it with the next side larger bit, and sure enough, that one snapped off inside too. After buying a set of Dewalt cobalt bits I pushed as hard as I could but made almost zero headway -- those are about the least aggressive bits I've ever used (returned them next day). I decided to give up on that bolt and moved to the other one, but was very careful about using a good fine punch and hitting the center of the bolt, and then very carefully (and vertically) drilling into the bolt with a very small bit, and working up four more sizes until I got to the correct diameter hole for the proper easy-out. I thanked God many times when that bolt (what was left of it) finally made it's way out. I chased the threads a few times, bought a new bolt, cleaned the pan and magnets, mounted the new gasket very carefully (everything was very carefully at this point), and slowly tightened all bolts in a criss-cross pattern and torqued them down. Remember, one of the holes still has the broken bolt so it's not pulling in the pan at that point. After following the filling instructions and checking the level at 40C, I drove it about 10 miles, and no leaks. After I've ran it another 20 miles, still no sign of leaks. This is a testament to the gasket quality and the rigidity of the oil pan (thanks VW). Changing out the front & rear diffs (Supertech synthetic 75W90) and transfer case (Rock Oil Gearaxl TF0870) fluids was a complete walk in the park by comparison. I did notice the front diff was slightly low after draining, both diff oils were pretty clean, but the transfer case oil was pretty dark. Lesson learned? Be very patient and careful when drilling the "starter hole" during a bolt extraction process. Again, big thanks to everyone who posted about their experiences with fluid changes, especially transmission. I'd do the flush again in a heartbeat -- very straightforward and actually fun! If it weren't for the broken pan bolts, that would have been quite enjoyable as well. ?
