With a setup like the B12, the words "unfortunately" shouldn't be used anywhere lol+- 3in drop. NICE. I measured a 4.25in wheel to fender gap on mine. unfortunately I'll stick to OEMish look with my setup.
yes and no. I know some coilover were available, but I wasn't entirely sure it would fit the purpose of the vehicle. I mean, I appreciate more it's comfort than it sporty attitude. I also wanted something that was well known as robust. The Ceika kit looks pretty good, and I really appreciate some of the features (dual springs, build to specs, ...)Like the ceika or bc racing? He didn't know they existed, but he made the right choice. Only thing better he could have done was some KW v3 for 3x more
Like mentioned above, I wasn't sure what product were available... and if they were robust. It all started with my ignorance of the R-line specs; I was shopping a drop (H & R) + Bilstein B6 and the specs were what I was looking for (not knowing the R-line VS H&R were about the same height). I placed the order and THEN discovered the B12 kit. So I urged to cancel my order, refused packages and all. This was a mistake as it would have been about the same as this B12 kit; for about the same money.@zambony excited to hear how the B12 turns out. I'm curious, why did you go with the B12 kit over adjustable coilovers? It seems like there are a few options in a similar price range (but perhaps with less brand confidence).
Yes exactly. These are not my forever wheels.Man, that thing is slick. Love it.
Instead of spacers maybe try different wheels with better offset
I'll have to check my current ET as they poke more than my stockers. Got them with a winter set off a Q7 owner. Just a set of cheap RAC R02's. At least they are rated at 900kg+.It looks very very nice indeed. If I were to do it all over again, I would definitely go that way. How is the comfort?
I emailed H&R trying to get some specs for spring rates or difference between the model for Cayenne & Touareg, they do not share the information. Apparently they are progressive springs and there is not one general way to measure. Maybe I am over-simplifying things, but it sounds like it should be as simple as force VS spring compression. I emailed Eibach to get an idea of the spring rate, no luck there either.
Anyway, I'll measure the Eibach springs force VS displacement on Friday.
Installation is schedule to be Tuesday August 17th, I should have received my rear top plate by then!
As for cost wise, The B12 kit was 1750$, add another 345$ for the rear top plate. I am not installing them myself, got a quote for 6.5h @105$/h since I am bringing my own parts + 100$ for the alignment. Ride height shouldn't be significantly different, but I doubt it has been aligned since it left the factory so it is worthwhile considering tire price in 20in.
As for wheel offset, I am running 20in Cayenne wheels (ET60 I think) with 10/15mm spacers Front/Rear
to be continued!
So I see lbs/in. My springs are 16kg front and 12kg rear.
The r-line springs are upgraded from stock so could they be the same as the gts springs?Stock touareg springs are around 450lbs and cayenne GTS are around 500lbs if I recall correctly
Yeah it looks good. Hard to see the actual gap but from what I can see its a good height.Just an update on my B12 kit. This is how it sits at the moment. I would say approx 3/4in drop over R-line. Ride is marvelous. My ideal would have been 3/4 to 1in lower, but I am still pleased with the look considering the vehicle size and purpose. I would call it OEM+ fitment (except for the black wheels)
Less diving under cornering yet still very comfortable. My ride being a 2014, just a shock refresh (even OEM) would have make a difference. Combined with the lower springs and I think the Bilstein B6 are superior than OEM... I am very pleased with the result.
