1 - 20 of 84 Posts
Have a completely stock 2014 T3 R-Line. Found some Godspeed coilovers for it. Has anyone on this site had experience with Godspeed products? Thought about going with the H&R cup kit but with its 1.2"-1.4" or 40mm lowering potential its just not enough IMO. I currently have a 5.5" fender gap with the stock 275/45R20 tires on it. I do not want slammed but a 1.5"-2" gap would be preferable as long as the camber isn't stupid. Any knowledgeable input would be greatly appreciated. Thanks.
Bilstein b6 or if you really want to get nuts any KW variant.
+1
Dropping an SUV is ghey
I am in the exact same boat. Literally LOL. 2014 R-line. I was hopping for a 1in extra drop, but it seems quite hard to get unless to go full retard with a KW T3 kit which is very expensive.
I have been trying to order the Bilstein cup kit (which comes with Eibach springs, 0.2in less drop than the H&R), seems backordered for quite a while now. BTW the drop is over a regular trim Touareg, not the already lower R variant. I expect 0.5in drop, not more.
The Bilstein B6 strut is not designed for drop, the B8 is. Some people ride the B6 on lowering springs without issues, I am sure it fits. Maybe just less durable and a bit more bouncy. I didn't find a way to ordered the B8 separately.
BTW I intend to change the rear top plate at the same time (bearing) because of the labor involved for the replacement and the fact that it is 7 years old. The front struts have no bearings in the top plate.
I have H&Rs with Bilstein B6s on my 2014 R-Line. The Spring/Strut combo improved the ride significantly. Dropped it a pretty significant amount over stock.
If you want coilovers, I would look at more reputable brands such as KW, Bilstein, etc. I believe, someone needs to correct me though, that Cayenne 2011-2018 suspension parts should fit. The Bilstein B6s were universal across Cayenne (2011-2018) & Touareg (2011-2017). I'm not sure if the strut top hats/plates are different across the platforms though.
Looking into it now, I may have tried BC Racing Coilovers.
243706
No offroading here in my rig (Hence the R-Line to begin with😄) . I had a Jeep and an Xterra before this and had my time of offroading. I'm mostly on-road adventures now!
Good looking ride mad doc
I have H&Rs with Bilstein B8s on my 2014 R-Line. The Spring/Strut combo improved the ride significantly. Dropped it a pretty significant amount over stock.
If you want coilovers, I would look at more reputable brands such as KW, Bilstein, etc. I believe, someone needs to correct me though, that Cayenne 2011-2018 suspension parts should fit. The Bilstein B8s were universal across Cayenne (2011-2018) & Touareg (2011-2017). I'm not sure if the strut top hats/plates are different across the platforms though.
thanks a lot for the picture. Can you measure the wheel to fender gap (or center of the wheel to fender line) please? I am curious to see how much it dropped. Are theses 20in? it is always a challenge to see the wheel details on black wheels.
Ask me how I know ;)
Correction - Struts are B6s. I don't know if they make B8s for this chassis? B4's are OEM replacements I believe.
I'll take some measurements tonight and report.
I ma no expert, from what I understand
B4 = OEM
B6 = Nitrogen filled shocks
B8 = B6 with shorter rod and different valving for lower ride height.
B8 are available, but I only found them in the cup kit (fix height) which they called B12. this is what I have on order.
B14 (not available for this gen Touareg) is a coilover (adjustable ride height)
B8 is available. Pretty badass setup.
Well shoot. I had the H&Rs and kept looking for something better than the B6 and came up empty handed.
~18.5" F / 17" R hub to bottom of fender. I may have to remeasure rear.
The kw setup is way better than the b8, but the b8 is a killer setup.
Reactions: zambony
I've had H&R Springs with B6 struts on my 2012 for over a year with no issues. Handles like a sporty car. I even have staggered 19" Panamera Turbo wheels. They bolt right up, just had to add properly tall tires.
I'm still on the hunt for coilovers though. I want like a 1 finger gap for that "Big GTI" look.
Pic:
244479
The H&R sport springs simply lower it to where a Cayenne with air suspension would be if it were in the lowest setting. Nothing crazy. I don't off-road it, so no need for mid or high height anyway.
Also, running staggered wheels hasn't been a problem with the AWD. And before you say I'm crazy, the X5, Cayenne, and various Porsche sports cars all run staggered AWD setups stock.
Discussion Starter · #19 ·
PN: MMX2890-B Godspeed Coil Overs. Honestly for the price I might just bite on them. They don't look cheap but no idea whats inside.
244483
244482
1 - 20 of 84 Posts
