Heated Steering Wheel
yuyueyuyue
Did you ever figure out how to get the heated wheel to work. I have just installed the DSG and Heated wheel along with the clock spring ending in H which should add the power to the wheel for heat.
I have activated Heated Steering wheel with VAG-COM on both steering wheel -16 module and Auto HVAC. This brings up the Heated Wheel Button on the Climate control in the RNS.
This is my problem: As soon as I turn on the heated wheel I blow fuse # 8 (Tire pressure monitoring control module -J502- Electronic steering column lock control module -J764- Steering column electronics control
module -J527-) on the Drivers side panel. It came from the factory with a 5 AMP fuse, however I looked at this diagram and it says fuse # 8 should be a 10 AMP.
Also, I do not have a fuse # 11, it is missing.
What have you determined needs to be done after installing the right parts and coded correctly?
ANy help will be much appreciated.
-Chris
yuyueyuyue
-Chris
