1 - 2 of 2 Posts
Was poking around with the VCDS to reset the "Service Now" notification and noticed the ESI: Oil Quality data field in the Instrument module (under Adaptation). Mine indicated "poor oil quality."
Is this a dynamic measurement block with some level of logic to toggle from good to poor? I changed the oil a couple of hundred miles ago, so I set it to good quality. <shrug>
The user enters the oil quality dependant on whether conventional oil or Long Life oil is used and in conjunction with the correct adaptations for either fixed or extended flexible service.
You don't mention it but in some circumstances changing these adaptations can result in an error in 17- Instruments, something like "No or incorrect basic setting."
1 - 2 of 2 Posts
