Chassis's step by step guide was closely spot on. I did have to do a couple extra steps that I didn't see listed.
1- Unplug the seats electrical connections. Without doing this I couldn't lift up front section of the rug area to get to the battery cover.
2- Unplug (carefully) the small electrical connector from the negative battery connector.
I did also then rest the front seat on it's back on the rear seat. This way it was totally out of my way when I worked. May not be necessary for everyone but for me it was better.
All total it took about 45 mins. to do the job and that was with having my coffee and a cig. in between.
I installed an Autocraft Platinum AGM battery size H9. 950CCA, 1,000 cranking amps, 100AH with a 190min. reserve capacity. It fit like a glove.
Since I got done with the job so fast I decided to change out the in cabin air filter as well. Winter's coming and I know I'll be using the HVAC system a lot more. Glad I did as the old one was full of dust/dirt.
