1 - 16 of 16 Posts
2011 VR6 3.6l
All the kudos goes to this thread:
I thought I at least do a little write up on how I did the retrofit and supply all the sheets I used as well. There were some head scratching moments, but it's all working now.
Parts list I used:
Part #Description
7P1927135Height Knob (center console)
7P6927127LCDC/Lock Switch (center console)
7P6927347Control Module Bracket
7P0907553Control Module
7P5616039Air Struts LHS FR
7P5616040Air Struts RHS FR
7P5616020Air Struts RHS RR
7P5616019Air Struts LHS RR
7P0616006Compressor
7P0698014Valve block
7L0698349Valve block bracket
7P0698007Full compressor assembly
7P0616201ATank
7P6959511Krear loader switch
7P0616213 height sensor FL
7P0616214 height sensor FR
7P0616571 height sensor RR
7P0907508Aacc sensor
7P0616706DBlack Pressure Line
7P0616708 (A/B)Suction Line
7P0616785ASuction Line 2 (might not be needed)
7P0616719GViolet
7P0616762CGreen
7P0616763ERed
7P0616764DYellow
7P0616657ABlack Exhaust Line
7L0616758Valve Connectors
7P0616047Grommet 4
7P0616860Grommet 1
7L0616757Push on Connector for Tank
Electrical Connectors (need to double/triple check these, but this is some of them)
Connector Part NumberDescription
1J0 972 483Acceleration Sensor Connector
8E0972416B
1J0973752Compressor
8E0971980Connector for Height Knob 7P1927135
4H0973712AHeight Sensor the "A" is important
A0015452703Control Module Connector 48pin (Mercedes Amp Wiring connectors)
A0015452703Control Module Connector 30pin (Mercedes Amp Wiring connectors)
1J0973715Solenoid
8E0972712Trunk Switch
1J0973703Compressor
2011 VR6 3.6l
Discussion Starter · #2 ·
Part 1 - stripping down the car. I probably did overkill and might not be needed, but I stripped it down to metal pretty much. Used mostly ElsaWin to figure out what to remove first and where those "hidden" bolts are sometimes.
244891
2011 VR6 3.6l
Discussion Starter · #4 ·
Part 3 - Mounting the Air Tank.
244893
There are holes in place and you just need to use rivets (N90777902) (10) in the diagram above. It's impossible to find the double sided bolts (12) from VW, but there's a Dorman 29203 part #. I only used 1 to mount it on the side.
For the front I had to get a little bit more creative, because the grommet (4) I couldn't find and my tank doesn't have that weird lip in the front. So I JB Welded an M12 nut in the hole of the tank, shaved down a half of a double sided bolt (N90967801) and kept the M8 fitting to screw in the front.
244894
244895
244896
244897
Automotive tire Synthetic rubber Automotive exhaust Automotive exterior Bumper
244899
2011 VR6 3.6l
Part 4 - Mounting the Compressor
Nothing really special here, there's one bracket that's needed that I found from @etischer post on his PDC air suspension. Part # 95835821000
Part 5 - Running the Air lines
The original lines are the best, because they come with all the kinks to where they need to be placed.
Yellow (rear right), Red (rear left) and Black line (air tank) (the one that has a "U" kink in the middle) go inside.
Purple (front left) and Green (front right) are for the front. I used the diagram below to guide me.
244900
The hardest line by far was the purple line. For easier access, remove the ECU/TCM (I forget which one it is), in the front under the rain guard. There's one hole for the passenger side. Then fish it through under the windshield wiper assembly in the middle. I also lifted up the Relay box on the driver side to get easier access to fish it through a similar hole on that side. You have to start from the inside of the engine bay and push the purple line to both sides so the grommets fit nicely.
Purple line.
244901
244903
244902
2011 VR6 3.6l
Discussion Starter · #6 ·
Part 6 - Running all the electrical wires.
Used the wiring diagram from ElsaWin pretty much to the letter.
The CANBUS H/L can be found in the main channel/main harness on the passenger side of the car. The cable also runs into the Parking Brake Module (J540), so I tapped into that.
244905
For the new switch and knob in the center console, it's a matter of rewiring the cables going into the old ESP button and splicing into the ground cable that's already existing. There's only one cable that needs to go the module from the center switches.
244906
Some more wiring pics:
244907
244908
244909
244910
244911
2011 VR6 3.6l
Discussion Starter · #7 ·
Part 7 - Install the Air Suspension
Once you made it here, it's time to install the air suspension :) Don't have any pics unfortunately, but the way I did it was to lift up the lower control arm with a jack, then use the spring compression tool (I bought the Snap-On ones, but generic ones should do the trick). Removed the top nuts from inside the engine bay.
Then I went ahead and removed the bolt/nut for the stabilizer bar - I used a joint remover tool here to push it out of the upper control arm. After that removed the bolt on the bottom.
I didn't remove any bolts for the brake lines or otherwise, I was able to get it out in one piece and put the air struts in without any problems.
Connect air lines and also connect the struts to the twisted pair electrical wires.
2011 VR6 3.6l
Discussion Starter · #8 ·
Part 8 - VCDS coding.
I used VCDS to do the coding and adaptation. While ignition on, code the 34 - Level Control Module, mine was all zero'ed out.
[34 Level Control Module]
Long Coding: 14210000
After that check off that you have the Level control installed.
[19-CAN Gateway]
[Installation List]
- Scroll down to 34-Level Control and put a check-mark next to it.
[Save Coding]
Next was to update the ABS coding:
Original Coding: 5B7613C349242554DAF5C89B92DAA4407700
Updated Coding: 5B7613C34B242554DAF5C89BD2DAA4407700
(Highlighted the bits that had to change)
Next I went into
[17-Instruments]
Used the long coding helper to tick off "Daempfer regelung".
Next into
[55-Headlight Range]
Used long coding helper to remove the checkbox for getting data from Sensors, but get it from CAN instead.
Next off to filling up the air tanks. For this, you will need to start the car (or at least I did). Close all the doors (also not sure if this is relevant, but I think it is?).
Go into [34-Level Control].
Enter the Security Code (VCDS will prompt the code - 210673).
Go to Basic Settings.
Do the "Bleed" channel, use the type "Complete" and hit go. The car should go all the way down.
Attach the nitrogen tank to the Air Tank using R134A low fitting and pressurize to 17bar/150PSI.
Now do the "Filling" channel, use the type "Stage 1", keep the pressure right around 17bar/150PSI while the filling process is going.
After that, go into Adaptation.
There's 4 channels where you need to input the measurements between center hub cap and arch well. Left Front/Right, Rear Left/Right. After that go into the channel "Complete Height Calibration" and change the value to "Yes" - mine was set to "No" initially.
[[ will post VCDS pictures later ]]
2011 VR6 3.6l
Discussion Starter · #10 ·
Addendum
Nitrogen Filling
For Nitrogen Filling I had a store called AirGas (welding supply store) that sells/rents out Nitrogen containers, my store is a super friendly bunch.
Tools needed:
1. Nitrogen Gas Regular (CGA 580 fitting)
2. AC Manifold Gauge Set R134a - the low pressure fitting fits on the air tank.
Nitrogen Tank >> Nitrogen Gas Regular >> AC Manifold >> High Pressure side >> Low Pressure fitting >> Air Tank
Then regulate the nitrogen going in.
2011 VR6 3.6l
Discussion Starter · #13 ·
The method I used required the following items:
  1. VCDS
  2. Nitrogen Tank with CGA-580 Connection
  3. CGA-580 Regular
  4. AC Manifold set
From a process, I did the following:
  1. Connected Nitrogen Tank to the CGA-580 Regular and the Regulator to the High Port of the AC Manifold.
  2. Connected the high port of the AC Manifold with the Low Pressure fitting to the Expansion tank under the car.
    1. This is usually capped with a black plastic cap that can be unscrewed.
  3. in VCDS Go into [34-Level Control].
  4. Enter the Security Code (VCDS will prompt the code - 210673).
  5. Now open up the Nitrogen Tank and the pressure on the AC Manifold should read around 17bar/150PSI.
  6. In VCDS, change to the "Filling" channel, use the type "Stage 1", keep the pressure right around 17bar/150PSI while the filling process is going.
This is pretty much what I did - let me know if that helps or if you have any questions.
1 - 16 of 16 Posts
