1 - 6 of 6 Posts
Planning on installing LED DRLs in left and right front bumper grilles.
Can the grilles be removed somehow without removing front bumper first?
On the T2, that is... and preferably without breaking anything in the process. ;)
Planning on installing LED DRLs in left and right front bumper grilles. Can the grilles be removed somehow without removing front bumper first? On the T2, that is... and preferably without breaking anything in the process. ;)
One word answer......NO.
Stuart...
Stuart...
Bummer. That's what I was afraid of.
Fortunately the DRLs (5 pcs per side) are round shaped with about 20mm diameter, so I might just be able to thread them through the grille openings from the outside.
Out of curiosity how are you wiring these?
The plan thus far is to take both terminal 15 (ignition +12 V) and side light signal from the headlight wiring harness.
I'm planning to wire the cables from here down close to the border between the front grille and the front wheel well (identically for both sides).
If the grille thing won't work then I will probably drill mounting holes in the fog light panels (close to the upper edge). It should still be high enough there...
1 - 6 of 6 Posts
