I did this job and wanted to share some pics.
The Treg had developed a serious coolant leak on the passenger side bank (LHD). But the leak was not visible outside or underneath the car. Coolant was leaking on the aluminum coolant return line and evaporated leaving only limescale traces on the return line. I had to remove the intake valve to find out.
The leak was due to the previous owner(s) using tap water I guess as the the pressure was pushing all that accumulated limescale out causing the hose to bulge at the combi valve port. The clamp crumbled to pieces when I removed it.
I replaced the combi valve too. I got a used one for a few euros. Tested good with a vacuum pump. I also replaced the hose coming from the V55 secondary pump. This hose is not sold separately by VW. It is connected to another hose (moulded) going to the coolant expansion tank. I got one on ebay. It came from a 3.2 Porsche Cayenne.
Before:
Before:
