1 - 3 of 3 Posts
Good morning,
I am putting some 35mm shock and strut spacers on my Treg and I want to fit the largest tires that I can after install - without any rubbing or issues.
Does anyone know the maximum tire diameter that will fit a stock T1 V6 (gas) Touareg & I can back in to the tire diameter with the added 35mm height?
From what I have read on other forums it seems to be in the neighborhood of 31.5" diameter is the max tire height for a stock T1. I figure if I go up 35mm with the spacer that I would add another 1.5" to get to 33" without any issues.
Does this sound correct?
Thanks, Dave
2005 Touareg V8
Maximum is 31.5". I have fitted 32" with 15mm spacers 60mm offset wheels. no rubbing. I remember someone put 32.8" with minor modification. Read these two threads.
2010 TDI w/ air
Even with the lift, you'll have to trim and massage things to fit 33s. 32s should be fine.
Reactions: Micheld7
1 - 3 of 3 Posts
