1 - 17 of 17 Posts
For those 3L V6 Tdi owners who have or get the dreaded out of range manifold flap fault or a variant of that i now have an easy permenent fix available. It only requires about 15 mins to fit to both manifolds with 2 steel brackets i make and completely eliminates the fault and prevents it from ever reappearing. It can also be used if you dont have the fault and will assure you don't get it ever. For those with the fault due to the swirl flaps being faulty fitting the brackets will stop all faults. Use of these will negate the expensive need for both manifolds to be removed and replaced or rebuilt. These are available for $120 shipping included to anywhere in Australia.
Regards
Drag
As additional information the brackets are a far better alternative to the diesel geek beautifully machined aluminum units that only provide control of the arms in one direction (mine do both directions) and as a kicker cost about $80 Aud less and fit the 3L Tdi BKS (165kw) eng in the T1 which the diesel geek units do not fit correctly
Regards
Drag
Sounds like a damned good idea for any Tdi owner to get a pair!
Hey Drag ... do you still have 'em ?
Any qualification needed about models/years/ etc ... or are all T1 & T2 TDI's 3.0L covered ?
Discussion Starter #11
Yea still have 2 sets left
That's the beauty of these vs the diesel geek mine fit both T1 & T2 V6 tdi and control in both directions of travel.
The diesel geek units only control in one direction and only fit the T2 CASA eng's
PM me if you want a set $120 incl shipping and instructions only 20 mins max on a cold eng to fit.
Regards
Drag
Fitted my kit.
As Drag said, only 20 mins max on a cold engine to fit.
So far so good.
Jim
Discussion Starter #13
Fitted my kit.
So far so good.
Jim
Thats good news Jim glad to hear they wooked as i said they do.
I thought you said you had an issue with one of the manifold motors?
regards
Drag
Beyond Diesel Geek
Hi Folks,
Thanks again to Drag aka Dragline 1570. I have just replaced my Diesel Geek CASA Inlet Manifold limit stop with Drags recommended alternative. Although the "Diesel Geek" product was an excellent piece of machining and created a fixed stop for the manifold actuators it only did this in the full open position ( the at rest engine off position). The travel limit ( full open position) relied, as VW does, upon the link arms and butterfly valves in the manifold. Not a perfect solution from how I understand this mechanism to work.
The replacement product is made from pressed plate steel, as compared with the "Diesel Geek" product being machined alloy, It also affixes in a slightly different manner utilising the stepper motor ( actuator) mounting screws, but the opposite ones to the DG product. Personally I would have preferred the "Diesel Geek" units if they had provided both limits, as I feel the machining is excellent.
I have included some photos to show how it mounts and the different designs.
Hope this is helpfull to somebody.
Kind Regards
Stuart..............
Discussion Starter #15
Thanks Stuart
I am glad you are happy with the units i supply.
You will now never have the dreaded limit stop fault again.
Just waiting on more positive feedback from another member i sold a set to
Regards
Drag
Hi Folks,
Kind Regards
Drag
After 7 months all is still going OK with the mod.
I don't think that the electrical connector was seated correctly.
1 - 17 of 17 Posts
