1 - 3 of 3 Posts
Hey CT, first post here but I've been cruising the forum for a while getting some great info for my 2005 V8 :D
I know there have been a few posts about this subject (like this one) and I've done a bunch of searching but I have a specific question that I haven't found an answer for. I have a headlight leveling error in the MFI screen with the orange error logo. I know there are two leveling sensors, one front & one rear. I scanned for the error codes with vagcom and came up with this:
Is there a 'control module' that's separate from the level sensor that's under the wheel well? Or does this just indicate a bad front left level sensor and that's it?
Also is there anything to do in vagcom once I install the new sensor or should it just work right away?
I've ordered a new level sensor from my local VW dealer for $147.35 CAD (p/n 7L0616213C). Just trying to get a jump on whether that's the only part I'm going to need to fix the problem.
Thanks!
Go unplug both sensors and verify there isn't corrosion at the pins which is very common for 04-06 Touareg. If you find corrosion, replace the sensor and wire ends (or pins) don't skimp or you'll be replacing the sensor again shortly.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Great advice, thanks!
1 - 3 of 3 Posts
