1 - 20 of 29 Posts
T1 AFS bixenon projectror upgrade with retrofitlab MD1S projectors.
https://www.retrofitlab.com/en/car/audi-a4-s4-b6-bi-xenon-md1s-1.html
Started this project and already i need to warn that this project is a PAIN!
For first, the permaseal in housing is really hard to remove. I removed it with help of heat gun and still had to cut some of the housing to get the clear part out. After that it is pretty ok job to take things apart. But nothing seems to be just plug 'n play...
Here is a link to the pictures.
https://goo.gl/photos/NF3d2fWvF6S7DSDc7I
I started with the right hand light because it was the worst. As you can see from pics it had yellow light and the reason for it is clear. Projector reflector is badly burned.
You need to use adapter plates that come with projectors in order to mount them to afs cradle. You still need to do some cutting to new projector and the cradle to make them fit together. So you better have a dremel or similar at hand.
Project continues...
Discussion Starter · #2 ·
One thing to be aware when fitting the new projector to the cradle. Measure the length from mounting surface to the edge of the lens holder. It should be about 50mm. This way the shroud or what ever that collar is called around the lens moves nicely in the other collar around it. I had to raise the projector from the mount surface for about a 4mm.
You have to modify a lot the cradle and projector to make room for swivel action. Also right in the corner of the cradle there is a position sensor. Make sure the circuit board does not touch the projector when it turns.
Very sharp light now, but had afs error. Now thinking about it i remember both turn motors look the same. I guess you can mix the wiring... :D
Anyway i add a picture of the light pattern and brightness this evening. Remember i swapped just the right side projector for now. Next one will be faster.
Quite a difference!
Discussion Starter · #6 ·
No, thats the starting point in the pictures. Its getting dark just now here so it takes a little while to take a new pic.
But then I re-read the thread and understand now how dim the right light really is!
Discussion Starter · #8 ·
Ok, now there is new pics with both low and high beam. New projector is in the right side headlight.
Discussion Starter · #11 ·
I was planning to change the left one this weekend. That new one on the right is so bright that that alone is better than both old ones together. I was planning to put a led light bar inside the bumper but now i dont know if i even need one anymore.
Trying also to fix the left one that is not turning anymore. Hope its just the wiring but i'm afraid the afs module is broken.
Discussion Starter · #12 ·
Afs error: " right swivel sensor malfunction" is now fixed. Sensor had a bad solder in connector pins. Didnt like me pulling the connector out.
Toy Thermometer Measuring instrument Plastic
Anyways, the other headlight is now glued together and now on the second one i took better pics to show where to cut and grind if you want to do this the "easy" way. Im going to add those pics here after editing arrows to them.
Discussion Starter · #13 ·
Here are the cutting locations and measures needed. Headlight itself is pretty easy to put in pieces once you get the clear face out. Bezel around the lens needs to be glued to lens holder. You might want to cut out the teeth inside that were holding it to old projector.
Vehicle
Auto part Engine Vehicle Automotive exterior Motorcycle accessories
Auto part Automotive exterior
Auto part Headlamp Automotive lighting Engine Carburetor
Auto part Wheel
Auto part Differential Rotor Machine Metal
Auto part
Auto part Bicycle part Automotive engine part Bicycle drivetrain part
2006 V8 Touareg AIR, nav, hid
...As you can see from pics it had yellow light and the reason for it is clear. Projector reflector is badly burned.
Thank you for all the pictures. You have moved the knowledge base forward with this post.
I have seen several threads about bad head lights recently. And I think you have stumbled across the problem. The reflectors are going bad.
If you have a really good picture of the condition of the old and new reflector you could post, I think it would be a benefit to all.
Discussion Starter · #15 ·
Not the best picture, but this ia what the old one looks. Could't take a picture of the new one because it was not made to be opened. But this is how the reflector burns. It is possible to restore it but that costs allmost the same as new projector kit.
Auto part Metal
Anyone done this since Lauri?
I seriously need to do the same thing for my new to me T1. Getting the housing apart seems like the hardest part. The refelector on mine must be burnt, as even with new Sylvania D1S bulbs it is way too dim to be safe to drive at night (maybe half as bright as my Corrado with Euro housings and Osram rally bulbs). But then even with new valeo housings, the output is apparently crap. This sounds like a better (and less expensive) alternative.
I will be looking forward to some mod reports from hallkbrdz :)
PS: If you decide to go crazy and posts some pictures, I won't object. ;)
1 - 20 of 29 Posts
