Hey Guys,
Does anyone have the alignment procedure for a '04 Treg V8 with air suspension (1BK)? Is it in Elsawin?, because I can't find it. I know the Hunter alignment machines have the procedure and I would like to have it. Can anyone help me out with that?
Service manual states the procedure is in the alignment machine. Here are the specs:
Front axle:
Rear axle:
Thanks! I've got the alignment specs from Elsa but I really am hoping someone can send me the alignment procedure. I know that the air suspension has to be locked in auto height and jack mode but isn't there more prerequisites before the alignment can start? Like gas tank has to be full?
I know that you need to lock air suspension and that the tank needs to have at least 3/4 (I always make sure it is close to full) and the tires should be in good shape with close to even wear.
AFAIK, that is the list of things that must be done.
