Adding to this Thread -
About 3 weeks back, on a lovely -15F Sunday morning, I used the remote-start to fire up the 2004 V6 Tourareg, base model. When I got in, there was a flashing brake light on the dash, a symbol for what looks like "drive train"? two axles, a tcase, wheels turned - "system workshop" and "brake fault stop" . AND - the transmission would not shift out of park.
Guessing it was the cold - and not having another option, I let it run a hour - and when I went outside to check it - it was fine. Took it on a trip to Anchorage - 50 miles each way - and it was no problem.
Next morning - same alarms, stuck in park - the shift interlock won't release and let me shift.
Lots of internet searching - maybe corrosion under the carpet at the driver's side?
Seems ok:
Car stuck a week at this point
. Lots of internet searching for the source (this is when you BUY THE VCDS FROM ROSS-TECH - DO NOT WAIT like I did) - I tried charging the battery to make sure it was topped off - and threw a part at it (which I hate doing - but now it's another weekend coming up - I can't even give up and take it to a shop (I have a bachelors in Auto and 5 years in a Ford dealership - usually I can fix whatever is wrong in my cars and I find that most mechanics know less than I do, and - throw parts it it )) - so I tried the Brake Thrust Sensor note cool custom-bent wrench
No change.
Came to my senses - I've known I'd need the VCDS should have bought it when I found out about it back when I was messing with the blower motor....
anyway - bought the Ross-Tech cable - yay ... ran outside....NOTHING - it won't recognize being connected to the car....waited till I could try my 2000 TDI Bug....nothing - like it's not plugged in
I had to get up at 4:50am to get out to the car at 5-ish to be able to call Ross-Tech at 9-ish am....
They were very helpful - suggested I try my OTHER car - a Jeep Liberty (really my daughter's car while my wife borrows the Jeep - long story) - and it LIGHTS UP!!! This is an important feature of the Ross-Tech VCDS - there is an LED that indicates the power and ground on the OBDII port is working.
So - check fuses that night. Found a blown fuse - VCDS works!
I was hoping the main problem would be magically fixed too - but no.
Codes for ABS and Transmission module not communicating.
No power to the three big fuses under the hood.....not blown, just no power.
So far I can't find what those do - are they powered by relays in the Trans and ABS module?....
The fun continues. I may have to flat-bed this thing and take it to the local VW specialist and pray they don't throw parts at it - it's way more expensive for them to do that than me.....I think the battery is original...it SEEMS fine, with correct voltage at idle etc...but it's a another "throw parts at it" thing and sometimes it makes sense to pre-empt that....it would cost me less than 200 to do it and more than 300 if a shop wants to....
