1 - 11 of 11 Posts
It suggests to me that one tyre is below pressure - pumping up the rear right tyre seems to be needed - not sure why the dealer couldn't tell you that.
2015 R Line V8
because...."dealer"
2021 Touareg 210TDI R-Line Wolfsburg Edition Pure White
On the big central display, drag the car symbol left or right to show oil level or tyre pressure. It will show the same tyre pressure indication that has come up on the dash display. The bracketed numbers are the target pressure. The bold figures are actual. The display in the dash has come up because your right rear actual is below the target. Note that there are 2 target settings, standard and fully loaded. For the V6, the rears are 37 standard and 40 fully loaded. I guess higher for the V8. You can get to the setting from the vehicle icon on the centre display.
Likely the driver side rear being more than 3psi below rating. Tire pressures lower than 3psi below the rating causes a warning. Happens when I rotate tires and forget to air them up (rear). 33psi F -39psi R.
But use a gauge you trust to check tire pressures, not the Touareg.
2015 R Line V8
It's an Australian vehicle, so driver's side is right hand side. ;)
Learner
After the last off-road trip I realise I now need to change the default so when pressures are lowered to let's say 25 to drive in off-road conditions the warning doesn't come up.
Best to perhaps change the fully loaded default to 20psi or thereabouts to cover for sand.
I don't think there's a Set button to do this via mfi so will be a recode job
MY21 V8 R-Line Grey
maybe it doesn't like misbalance? 44 vs 40 on the rear.
I know mine's super sensitive, especially when the tyres are cold.
Went up in the hills last April and it bleated at me every morning until they warmed up.
Discussion Starter · #9 ·
Yes I have thought of that. Run them all at 40 psi and no change. I had a puncture very early on after we bought the car new. It came on then and has been there ever since. I will get vw to look at it at the same time that they figure out why the stop start feature is not working. Regards Garry
It's warning you because the actual 40 psi on the RR is less than the target (41). Either inflate to 41+, or if you've set the monitoring system for full load but are just running normal loads, you can set it back to "Standard", which has lower targets than "Fully Loaded".
To do that touch the car symbol on the big screen, then use the left / right arrows high on the display to scroll until you show Tyre Pressure Monitoring System. Down low on the screen is a menu bar with a Load icon. Touch it to pop up the Standard and Fully loaded options. You'll see the actual pressure remain the same but the figures in brackets will change.
On the big screen, when actual are greater than or equal to target it will show a Tyre Pressure OK message. There is no corresponding low tyre pressure message on the big screen - in that case you get the display in the dash. Note that Vehicle Status OK with the green tick as per your photo is ignoring tyre pressure monitoring, ie verall status can be OK even when a tyre is low.
Discussion Starter · #11 ·
I do understand that. The pressure set at 40 is cold. Once warmed up the reading should go up approx 4 psi which is above the set number. I have never had a Tyre Pressure OK message.
1 - 11 of 11 Posts
