1 - 3 of 3 Posts
Hi I have a problem with the air sus on my v10. dash throws running gear fault after a couple of mins. car def lop sided. put into garage who have run vagcom which comes up with
01598 ( drive battery lower limit reached - intermittent )
01780 (sensor for vehicle leveling mechanical malfucntion- intermittent)
01400 (suspension level control lower limit reached - intermittent)
they tried to reset the suspension but the nsf will not take a value all the other 3 will. tried rocking drive and try recal again with no joy.
bought a new sensor and fitted to the nsf and still the same this corner will still not take a value to recalibrate.
Any ideas ?? Many thanks
If you have VCDS, then lookat this;
Ross-Tech: VAG-COM: Suspension Level Control Calibration
If you are in an area where salt is applied to roads to clear ice, then you may have a corroded air line fitting on an air spring. Worth doing an end-to-end integrity check of the air system before getting to deeply into it.
Stuart...
2005 mk1 Touareg V10 tdi in black
Hi v10tdi03,
Are you still on here? Did you resolve this issue?
Am currently having the same problem but with my back end jacked up to its highest setting.
Phil
1 - 3 of 3 Posts
