1 - 4 of 4 Posts
touareg v8 2005
hi,
please help me with this:
my toureg was working flawless until I have the warning traction control light at gauges and the knob of suspension height control is not working, also de esp button, lock suspension button, and the knob of suspension sport, confort are not working.
i already check the fuses at both sides, engine, battery
vcds dont recognize or dont read the suspension module, at engine says
Address 01: Engine Labels: 077-907-560-AXQ.lbl
Control Module Part Number: 4D0 907 560 DB HW: 8E0 907 560
Component and/or Version: 4.2L V8/5V G X010
Software Coding: 0007875
Work Shop Code: WSC 31414 000 00000
VCID: 69D22F2943A5870710-5102
1 Fault Found:
18005 - Powertrain Databus
P1597 - 008 - Missing Message from Level Control System (J197)
I read that exist another fuses under dash but I cant found it
also that exist a compressor relay
owner manual is poor about fuses
i found at web other manual of fuses but still poor information
hope you can help me
regards
2015 TDI Exec R-Line
Sounds like you either have a CAN-bus wiring issue to the 34-level control module, a faulty control module, or blown fuses for the control module. In the right dash fuse box, check fuses 27 (15A), and 48 (10A). Do you have any more codes, specifically in 19-CAN gateway?
Thanks for your help
Problem solved
1 fuse was not in place
(My wife goes to change a tail lamp light, and i dont know why somebody removes this fuse)
Do you have or let me know an url to know the fuses location to know what does each fuse ?
Thanks in advance
Google, that's what I did.
1 - 4 of 4 Posts
