1 - 13 of 13 Posts
2009 Touareg 3.6 V6 FSI
Hi,
I want to get a spare key cut to lock and unlock the car (2009 model) when I go surfing, I will leave the factory key with electronics in the car, it does not have proximity sensors, so guessing it is ok to leave it in the car. Also my car does not have the valet key that other high end models seems to have.
After reading few forum posts, it look like I can get a duplicate key (steel blade only) made for not that much.
Saw this blade for $15, and it needs to be cut. https://carkeystoyou.com.au/product/volkswagen-and-audi-surf-key/
One of the locksmiths I spoke with said a duplicate key like the above is good for locking the doors but SHOULD NOT be used in the ignition key slot, otherwise it will capture the key and will require an expensive trip to the dealer to get it to release. Is this correct?
I tried couple of VW dealers but they were not helpful. I am still waiting for their call back.
Below post says the locksmith needs to have access to key's transponder code, is this correct? If so where do I get this from?
If anyone knows a good locksmith in Sydney, Aus, that knows about these cars and can make a "surf" key, please let me know.
Thanks!
Yudi
2009 Touareg V6 TDI
This is awesome! I'm really into diving and kayaking and the touareg key has been a constant problem... I often end up trying to hide it under a rock at the beach and hope nobody sees me.
You don't need to worry about the transponder codes or anything unless you want it to work in the ignition- if it's just for the doors, and you keep the main key hidden inside the vehicle, a pure physical key should be fine.
I can't help with the plastic key situation, but I will tell you (if you have a hitch) that a hitch lock works for me just fine in the past. It's strong and barely noticeable. You can put everything from key, license, cash, etc.. They keypad has a cover as well, fyi.
Automotive tire Motor vehicle Bumper Automotive lighting Vehicle door
You could also use one of those hanging storage locks.
Tire Hood Automotive tire Automotive lighting Vehicle
I know this doesn't help with your original question, but just handing out some options you might not have thought of.
Discussion Starter · #4 ·
Tried one but then I came across this channel -
Promptly returned it.
Most of these types of locks are comically easy to pick. especially the number combo ones.
Hitch lock might be a little bit safer with the cover on, it might not be conspicuous. But the latch type ones dont even need any tools!
MY16 R-Line V8 Black (7P) + MY21 R-Line V8 Black (CR)
Many Insurance OZ Companies won't cover you if you use one of those key locks. They have proved to be next to useless against battery powered grinders or just plain old crowbars. Just get a dumb key cut (that you out in a stuf leash etc) and secure the original in a handy but safe spot in car, better still in a Faraday pouch to stop cloning.
2013 7P Touareg R line V8 4.2 TDI
Yes the problem is the thief just has to walk down the car park park at a surf beach until one of these locks is seen. Then a grinder or bolt cutter guarrantees acces to the car keys :(
If you use one of these you need to hide it and make sure no one sees you put the key in it. A metal door key you can take with you on the water is better IMHO
2009 Touareg V6 TDI
I could be wrong, but I think the thing about keys breaking off in the ignition only applies to plastic emergency keys, which some VWs come with: https://www.amazon.com/Replacement-Keenso-Emergency-Volkswagen-2009-2011/dp/B07NVLHPQY?th=1
A quality metal key won't break in the ignition, but without the immobilizer chip, won't be useful as an ignition key.
Edit: VW also makes a plastic 'valet key' that looks like a standard key, and lacks the remote features. I think this is the best option overall, as it still has the chip and can start the ignition but the rfid chip is totally waterproof and sealed inside.
Edit2: Googling online, the part "HU66T24" seems to be the key needed for a 2009 model (your car is the same year as mine)
He wants a steel valet key, not the plastic one which can break in the door lock (not the ignition) as the lock never gets used until there is a problem by which time any lubrication has long gone.
2009 Touareg V6 TDI
You're right, I was mixing my terms up a bit. The plastic 'valet key' just has a solid plastic handle with no electrical buttons, but still a metal key blade.
Yep they actually target them as they know the smart key is in them. They are just flashing signs saying "Pick Me Pick Me". The alarm will trigger with a dumb key which is OK, but you can recode a delay if you don't want attention while you root around looking for the smart key. A Faraday pouch stops both cloning from outside, and starting the Touareg after forced entry (alarm settings aside).
The easiest lock box thethers to break are attached to the wheel rim, theves just pull up beside with their ''Current Drive" (the last stolen joyride that's now stuffed or running low on fuel) and roll the front wheel over the lock box & pop - all but the very best open.
Current Vehicle #1 - 2012 Audi Q7 3.0L TDI CATA Current Vehicle #2 - 2014 Audi Q7 3.0L TDI CNRB
I want to know what kind of crap shorts you wear surfing. All my surf style shorts have the little tie down in the pocket you can attach your key to in addition to having a zipper.
See no reason to be leaving a key outside the car.
Sent from my SM-S906W using Tapatalk
By the way, it is very easy to release the key from the ignition if it gets locked in. Look closely at the ignition, you will see a little square plug a few mm from the key slot. Use a little pick or fine screw driver to just pick it out. Behind that little cover is a tiny button. With a pick, awl or small drill bit, you push in on that tiny button, turn the key left and the lock will release the key.
2015 Porsche Cayenne Diesel
Just get a valet key made and carry that with you. Or, do like a friend of mine does. He does some surfing and he got a valet key made, then glued a magnet on one side of the key head. When he parks and heads for the beach, he just has a spot on his car that he puts the key, way out of sight and pretty secure. He has also attached to different places at the beach (metal posts, back side of bathroom partitions in public restrooms, etc) so if there are crowds around, so no one really knows where he put his key. Just an idea.
1 - 13 of 13 Posts
