1 - 7 of 7 Posts
2021 Touareg 210TDI R-Line Wolfsburg Edition Pure White
I've got new plates on order for the CR in the Euro long size 520x110 that matches the front bumper mounting. The NSW standard slimline plates are only 372*83 for the fronts and just don't look neat on the mounting area.
Now I need to find some plate holders that will bolt up to the car and hold the plates without drilling them. I've seen a few advertised, but wondering if you guys have any recommendations?
2016 MY17 V6 TDI Canyon Gray Metallic
Yes I am in the same boat with the rear plates on my 2017 7P --- with a black rubberised bit that extends beyond the rear plates -- I dont think that would be very durable especially with standard plates or the QLD slimline plates.
Personally, I use 3M VHB "Red" double-sided tape. It's neat, there are no mounts, frames, screws, etc, and once it's properly adhered, it's on for good. Well, at least until you have a spare 30min and some fishing line :).
Get it on ebay: Genuine 3M VHB Tape Sheet Mounting Adhesive Double-sided tape 100mmx100mm | eBay
Oz
That's serious stuff! I've only seen the indoor 3M double-sided tape before and this is a whole another level. Not sure I'll use it for the plates, but I can think of a few other applications
Oz
I vote for this method.
I have done this on my last two Regs and bumped into my old 2013 7P recently and the Euro plates are still struck strong.
Trick is to form the front plate to the shape of the holder before adhesion.
Back plate mount a length of Aluminium flat bar with countersunk bolts onto the car and stick onto that.
Reactions: Wolfy
Definitely shape the front plate to fit...and yes, it's about as serious as "sticky tape" gets lol
I have personalised plates and when I changed from my '13 V6 to my '15 V8 I just took my time with fishing line and "cut" the tape away from the car by sawing back and forth. Doesn't do any damage and, once removed, you can use bug and tar remover to get rid of the residue.
If you form a full length seal then no dirt gets in and because the tape is so thin, the plate sits nice and snug.
I've used that tape to adhere letters back on (to a Range Rover) and even with such a small contact patch (literally just the 2mm wide edges of each letter) it sticks like crap to a blanket.
Give it a go - the tape isn't overly expensive - worst case scenario you take it back off...
Oz
1 - 7 of 7 Posts
