naudi02 said:
How can I reset the trip computer to 0 in the MFI? ( I have V8 w/Nav if it helps). THANKS!
You have two MFI memories - short term, and long term. The short term (display 1- indicated in the MFI) resets itself when the ignition has been off for an hour or more. Long term (display 2) keeps everything until reset manually.
Either memory can be cleared by pressing and holding the thumbwheel for a few seconds. I usually select the accumulated mpg display, ensure it's on the long term memory (2 is displayed), then press and hold the thumbwheel. The mpg display will change to show "-----" when it has been reset.
I'm pretty sure this is in the owners manual, but since the manual is so poorly written, I guess I can understand why you can't figure it out.
