Hi,
I have a 2004 V10 TDI that started acting up about a week ago.
Background: I put a NOS V10 motor with new turbos, accesories, and wiring harness in about 1000 miles ago.
After starting, it runs for 42-45 seconds (timed many times) and then throws a CEL for injectors 6-10 (5 faults, one for each injector, implausible signal, value of resistance too high). It runs rough until I clear the codes, then it starts running normally and nothing I can do makes the codes come back until I restart it. It does this probably 4 of 5 starts, whether it's fully warmed up or cold doesn't seem to matter.
The obvious suspect was the common wire from the ECU pins 31 +32 to the injectors via the connector on the back of the head, but I've checked that, all the firewall and engine bay grounds, and the ECU power supply wires. I kinda don't think it's an obvious wiring problem with how consistent the problem is, and how I can't get it to come back without shutting the engine off and restarting. I've done several hours of driving around, and plenty of idling. I've even pushed and pulled on the wiring harness to see if I can make it happen while idling, but nothing reproduces the problem except right after starting.
Maybe ECU going bad? Or something with the battery management handing off ECU power from the starting battery to the accessory battery? I think my next step is going to be trying to run the ECU with a direct connection to power and ground and see if it still happens.
I'd welcome any ideas or suggestions, I'm tearing my hair out with this one.
-Nate
-Nate
