1 - 4 of 13 Posts
KandC
2018 R Line V8
Discussion starter · #1 ·
Drove from home to Costco (approx 70Km) to get fuel this morning.
After refueling the car would not start, turned over but not enough grunt in the battery for it to start.
I did briefly see a error message "Park Brake Failure" flash up during one of the attempts to start it.
Car started fine at home earlier.
Managed to turn off the park brake and push the car into the carpark where we used Costco's starter pack to jump start the car ok.
Ran the engine for approx 4 minutes then turned it off and started it up again without any problems !
Drove it around to their tyre centre to get them to test the battery with their tester but he claimed it would not test the battery because there was some sort of load on the battery ?
Continued on our day and stopped on multiple occasions for various periods of time and the car started without a problem each time.
About to hook up the Ross Tech Cable and do a scan now.
Anyone had this experience ??
Kym
Discussion starter · #4 ·
Couldn't see anything in the scan that would indicate what the initial problem was.
A number of error codes stating low voltage but that was most likely when the battery had dropped voltage and would not turn the engine over.
Will have to go out and buy myself a smart charger as my 20year old 6/12V charger would not be good for a modern battery.
Discussion starter · #8 ·
Things have been a bit hectic the last two days .........
Scan is below.
The failure to start happened at 76297km on 2024.07.23
I am guessing the first attempt to start after refueling happened at 10:38:17
There are more error codes at the same km and later time which would have been further attempts to start up.
All the descriptions indicate low voltage which would be in line with the fact the engine would not turn over fast enough to start up ?
I have driven the car numerous times since and it has started easily every time when it is cold or hot !
Voltage at the terminals under the bonnet were 12.25V with the engine off and 14.31V with the engine running which slowly crept up to 14.59V
I have purchased a NOCO Genius 5 smart charger and have had it connected to the car for about 30 hours and it is now fully charged and in maintenance mode trickle charging the battery.
The NOCO Charger has a Repair Mode which is supposed to help recover batteries that are stratified or sulfated.
The manual has a warning stating the voltage may be as high as 16.5V during repair mode so I am reluctant to use this without isolating the battery, what is involved in setting everything up after the battery has been disconnected ?
2017 Touareg R Line 4.2L V8 TDI
Code:
Tuesday,23,July,2024,20:36:43:12603
VCDS Version: 24.5.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WVGZZZ7PZHD04xxxx   License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 11 31 13 15 16 17 19 28 34 36 3C 42
          46 47 52 53 55 56 5F 62 65 69 6C 6D 72 85 8B 8E 8F 90
VIN: WVGZZZ7PZHD046566   Mileage: 76429km-47490miles
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
47-Sound System -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CKDA)       Labels:. 057-907-409-V2.clb
   Part No SW: 7P1 907 409 A    HW: 7P0 907 409
   Component: 4.2TDI EDC17  H21 0001
   Revision: 52H21---    CVN: 45D6DCE4
   Coding: 292A4012436E00020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM42TDI1117P1907409A 001001
   ROD: EV_ECM42TDI111_VW52.rod
   VCID: 36362EE268C46E0ABDF-8062
   VINID: 9E65EAAAA1E0A985001061461807583A1A
2 Faults Found:
10380 - Engine Control Module
          P166D 00 [00100000] - Incorrect Installation
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 76297 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 38 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 12.320 V
                    Unlearning counter according OBD: 40
                    Mean injection quantity: 0.00 mg/stroke
                    Fuel high-pressure: actual value: 7900 hPa
                    Setpoint generation interior torque: 0.0 Nm
10062 - Fuel Pump
          P3044 00 [01100101] - Short Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 75966 km
                    Date: 2024.05.16
                    Time: 16:34:03
                    Coolant temperature: 31 °C
                    Intake air temperature: 26 °C
                    Ambient air pressure: 1020 mbar
                    Voltage terminal 30: 10.640 V
                    Engine status: COENG_READY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217)       Labels: 0C8-927-7XX-V2.clb
   Part No SW: 0C8 927 755 A    HW: 0C8 927 755
   Component: 64C05G0M.MOT  130 3066
   CVN: 096A7E83
   Coding: 010100000C008400000000000000000000000000
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 2F381B86979E5FC2FE9-807A
No fault code found.
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 41587445714963 Dataset Number: V03935253TE 0001
   Coding: 5B6B53C34B286F59DAF9CA99D2D8F660F701
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4CC26C0A064804DAFBB-8018
1 Fault Found:
171010 - Supply voltage
          U1011 00 [01001000] - Voltage too Low
          [insufficient voltage]
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 76297 km
                    Date: 2024.07.23
                    Time: 10:38:17
                    Standard Freeze  Frame Dynamic: 00 21 FF FD 20 00 00 07 00 00 01 00 80
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 JM    HW: 4H0 907 064 JM
   Component: BCM2 2.0      H44 0582
   Revision: 00002001
   Coding: 05960016000000000000
   VCID: 7DA4F1CE0DF27D523C5-8028
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H40 0046
   Serial number: 3217000108020008
1 Fault Found:
00955 - Key 1
            002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 158
                    Mileage: 69325 km
                    Time Indication: 0
                    Date: 2024.03.10
                    Time: 14:09:24
Address 06: Seat Mem. Pass (J521)       Labels: None
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000270568990
   Coding: 0038330000004201000001010101202020202121202020
   VCID: 343214EA7E387C1A83B-8060
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 CR    HW: 7P6 907 040 CR
   Component: Klima 4 Zonen H23 1608
   Coding: 38A620BEC0
   VCID: 06569E2258A43E8A6DF-8052
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0311
   Revision: 2202007S    Serial number: 00001751813301
   Coding: 26000014D0345D010029400780005D4C431D470823014241800000000040110000000000000000
   VCID: 6A8ECA926C7CFAEAE97-803E
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    170609  033 0021
   Serial number: 90243401170726100517
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 81106283
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
   Component: E1 - LDS  H02 0040
   Serial number: 00000000002208170221
   Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA128294000035481761
   Coding: 020300
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28231721403218
   Coding: 518D04
   Shop #: WSC 56374 003 1048576
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44D2442A2E18CC9A33B-8010
Address 11: Engine II (J624)       Labels: None
   Revision: 52H21---    CVN: E85A53E8
   ASAM Dataset: EV_ECM42TDI2117P1907409A 001001
   ROD: EV_ECM42TDI211_VW52.rod
1 Fault Found:
4087 - Engine Speed Sensor (G28)
          P0322 00 [01100000] - No Signal
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 76297 km
                    Date: 2024.07.23
                    Time: 10:38:39
                    Coolant temperature: 95 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 11.480 V
                    Engine start: start synchronization: EPM_MODE_WAIT
                    Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 1
Address 13: Auto Dist. Reg (J428)       Labels:| 4H0-907-561.clb
   Part No SW: 7P6 907 561 C    HW: 7P6 907 561
   Component: ACC3          H21 0400
   Serial number: 00000000000000
   Coding: 3704010101
   Shop #: WSC 13153 004 1048576
   ASAM Dataset: EV_AdaptCruisContrVW526 002012
   ROD: EV_AdaptCruisContrVW526_002.rod
   VCID: 3C223CCA56E8B45A4BB-8068
47 Faults Found:
2304 - Internal Fault
          B200F F0 [00010000] - Unknown Error Elaboration
          [FAULT_RAL_BPC_DRIVER]
          Intermittent - Not Confirmed - Not Tested Since Memory Clear
3840 - Internal Fault
          [FAULT_MON_MMIC_VCO_FREQ_OFF]
20480 - Internal Fault
          [FAULT_MON_MMIC_VCO_POWER]
4096 - Internal Fault
          [FAULT_MON_MMIC_VCO_FREQUENCY]
4352 - Internal Fault
          [FAULT_MON_MMIC_DRO_FREQUENCY]
4608 - Internal Fault
          [FAULT_MON_MMIC_MIX_OFFSET_INIT]
4864 - Internal Fault
          [FAULT_MON_MMIC_MIX_OFFSET]
5120 - Internal Fault
          [FAULT_MON_R_ASIC_INIT]
5376 - Internal Fault
          [FAULT_MON_R_ASIC_BUSTEST]
5632 - Internal Fault
          [FAULT_MON_R_ASIC_COMMUNICATION]
6144 - Internal Control Module Memory Check Sum Error
          B2000 00 [00010000] - -
          [FAULT_MON_R_ASIC_COMM_DEFECT]
6656 - Internal Fault
          [FAULT_MON_R_ASIC_MEASUREMENT]
7168 - Internal Control Module Memory Check Sum Error
          [FAULT_MON_R_ASIC_MEAS_DEFECT]
7424 - Internal Fault
          [FAULT_MON_R_ASIC_DMA_TIMEOUT]
7680 - Internal Fault
          [FAULT_MON_R_ASIC_RAMP_DURATION]
7936 - Internal Fault
          [FAULT_MON_R_ASIC_ADC_MAXLEVEL]
8192 - Internal Fault
          [FAULT_RAL_R_ASIC_BUSY]
8448 - Internal Fault
          [FAULT_RFM_RTCMON_AM]
69376 - Internal Fault
          [FAULT_RFM_RTCMON_LF1]
69632 - Internal Fault
          [FAULT_RFM_RTCMON_LF2]
8960 - Internal Fault
          [FAULT_RFM_RTCMON_FPRZ_OFF]
9216 - Internal Fault
          [FAULT_RFM_RTCMON_ADC_FILTER]
69888 - Internal Fault
          [FAULT_RCU_RADAR_INIT]
11264 - Sensor for Automatic Distance Regulation
          C110B 49 [00010000] - Internal Electronic Failure
          [FAULT_UAR_NVK8_31]
19200 - Internal Fault
          [FAULT_MON_5V5ATLAS_HIGH]
19456 - Internal Fault
          [FAULT_MON_5V5ATLAS_LOW]
19712 - Internal Fault
          [FAULT_MON_5V5ATLAS_OFF]
19968 - Internal Fault
          [FAULT_MON_VREF_HIGH]
20224 - Internal Fault
          [FAULT_MON_VREF_LOW]
20736 - Internal Fault
          [FAULT_MON_TEMP_MMIC_FAIL]
70400 - Internal Fault
          [FAULT_ACQ_TEMP_PLAUS]
34560 - Function Restricted due to Missing Message(s)
          U1111 00 [00010000] - -
          [FAULT_CIM_TIMEOUT_SCU_01]
91136 - Function Restricted due to Missing Message(s)
          [FAULT_CIM_TIMEOUT_LRRS_LOCATION]
78080 - Function Restricted due to Missing Message(s)
          [FAULT_CIM_TIMEOUT_LRRS_FOV_01]
78336 - Function Restricted due to Missing Message(s)
          [FAULT_CIM_TIMEOUT_LRRS_FOV_02]
79104 - Function Restriction due to Implausible Message(s)
          U1112 00 [00010000] - -
          [FAULT_CIM_CRCSCU_01_FAIL]
80384 - Function Restriction due to Implausible Message(s)
          [FAULT_CIM_CRCLRRS_STATUS]
61952 - Function Restriction due to Implausible Message(s)
          [FAULT_CIM_ALVSCU_01_FAIL]
138240 - Function Restriction due to Faults in Other Modules
          U1113 00 [00010000] - -
          [FAULT_CIS_ADS_FAIL]
138496 - Function Restriction due to Faults in Other Modules
          [FAULT_CIS_ADS_SOLL_FAIL]
138752 - Function Restriction due to Implausible Message(s)
          [FAULT_CIS_ADS_SOLL_INIT]
91904 - Function Restriction due to Implausible Message(s)
          [FAULT_OHL_LRRS_MEASTIME]
156672 - Internal Control Module Memory Check Sum Error
          [FAULT_EDC_ECU_DEFECT]
87040 - Function limitation due to excessive temperature
          B1050 00 [00010000] - -
          [FAULT_MON_TEMP_MMIC_HIGH]
155392 - Deactivation after Multiple Emergency Brake Activations
          C1143 F0 [00010000] - Unknown Error Elaboration
150016 - invalid data record
          B2005 00 [00010000] - -
          [FAULT_BPC_NVM_DATA]
150272 - invalid data record
          [FAULT_BPC_NVM_Download]
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 G    HW: 7P0 959 655 G
   Component: VW10Airbag00T H11 0048
   Revision: --------    Serial number: 003TU003E6YX Dataset Number: 7P6003V____ 1765
   Coding: 000000000000000000000000000000003054
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   VCID: 45D4592E2522F592245-8010
   Serial number: 3575LRB400S5BCHA6HV5
   Front Passenger's Side Airbag Crash Sensor:
   Serial number: 3585LRB400E59P4A5HIJ
   Rear Side Airbag Crash Sensor (on driver's side):
   Serial number: 3517ARB40614RMHIBG9R
   Passenger side rear thorax airbag crash sensor:
   Serial number: 3527ARB405B4RUNIE23Y
   Serial number: 3557BRB40674TRO2199J
   Serial number: 3567BRB405J4TRO2P0OI
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
   Part No SW: 4H0 953 568 M    HW: 7P6 953 507 AJ
   Component: Lenks.Modul   H06 0010
   Revision: --------    Serial number: 91560QF8000ER
   Coding: 000CFD
   VCID: 3D2431CE4D72BD527C5-8068
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0165193 TRW 20170529
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 883 S    HW: 7P6 920 883 S
   Component: Kombi         H15 0607
   Revision: 16240316    Serial number: 658110817592034
   Coding: 331733003F0C000801000C
   ASAM Dataset: EV_KombiUDSRBVW526 001030
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 4EC66602F05436CA95F-801A
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 7P6 907 530 R    HW: 7P6 907 530 G
   Component: GW-CAN-L-FR-M H15 6055
   Revision: --------    Serial number: 00000002695491 Dataset Number: V03935235BB 0001
   Coding: 0001037D00
   GVL: FF7F44E55D7F6E0000
   ASAM Dataset: EV_GatewVW526UDS 001008
   ROD: EV_GatewUDS_VW52.rod
   VCID: 47C853261F2EE782D69-8012
   Subsystem 1 - Part No SW: 7P0 915 181 C    HW: 7P0 915 181 C
   Component: Batt_Sensor  H07 0270
   Serial number: 44191L16165811563188
3 Faults Found:
66505 - Second (Slave) Engine Control Module
          U0115 00 [00001000] - No Communication
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 76297 km
                    Date: 2024.07.23
                    Time: 11:17:08
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 40 °C
                    System status: Awake_Timer_active
                    IN ESP_standstill flag: standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00001000] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 100
                    Reset counter: 26
                    Mileage: 56069 km
                    Date: 2023.09.11
                    Time: 15:20:40
                    Voltage terminal 30: 12.0 V
                    Control Module temperature: 26 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
12291 - Energy Management Active
          U140B 00 [00001000] - -
          [Powermanagement active]
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 76297 km
                    Date: 2024.07.23
                    Time: 11:07:25
                    Voltage terminal 30: 11.4 V
                    Control Module temperature: 37 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 7P6 907 049 S    HW: 7P6 907 049 S
   Component: Klima Fond    H16 1406
   Coding: 0000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_AirCondiHeck 001007
   ROD: EV_AirCondiHeck_VW52.rod
   VCID: 4DC4610EFD520DD2EC5-8018
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 AH    HW: 7P0 907 553 AH
   Component: PASM          H05 0960
   Revision: 00000000    Serial number: 00000172090394
   Coding: 15210001
   ASAM Dataset: EV_PASMConti 001005
   ROD: EV_PASMConti.rod
   VCID: 7DA4F1CE0D727D523C5-8028
2 Faults Found:
0628 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [Versorgungsspannung - unterer Grenzwert unterschritten]
             Freeze Frame:
                    Fault Priority: 13
                    Fault Frequency: 28
                    Reset counter: 1
                    Mileage: 780544 km
                    Date: 2043.02.16
                    Time: 14:04:55
                    Default: 00
                    Default: 7D
                    Default: 00
0786 - Electical Consumer Cut-Off Active
          U1402 00 [00001000] - -
          [Spannung Fahrbatterie - Abschaltstufe aktiv]
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 28
                    Reset counter: 1
                    Mileage: 657664 km
                    Date: 2123.10.24
                    Time: 29:48:58
                    Default: 00
                    Default: 85
                    Default: 00
Address 36: Seat Mem. Drvr (J136)       Labels: None
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000270569124
   Coding: 00383B0000004201000001010101202020202121202020
Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb
   Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
   Component: SWA Master    H08 0030
   Serial number: 0449259850 Dataset Number: 7P6764V____ 0009
   Coding: 030312
   ASAM Dataset: EV_LaneChangAssis 001028
   ROD: EV_LaneChangAssis_VW52.rod
   VCID: 3FD84BC647FEAF426E9-806A
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 7P6 907 568 A    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0030
   Serial number: 0449462318
   Coding: 030312
Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H03 0306
   Revision: --------    Serial number: 0000270698130
   Coding: 011D1620DE01459205080003
   VCID: 7AAEFAD21CDC4A6A197-802E
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0451754786
   Coding: 011B1E20A8B91095832006200F0000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 172
   Component: Sensor, DWA  005 0502
   Subsystem 2 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 3 - Part No SW: 7P0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS30.408  H03 0004
   Serial number: 0000FST001Q7ZLI00000
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 E    HW: 8V3 959 591 A
   Component: J394 PS30.408  H03 0004
   Serial number: 0000FST001QIG4T00000
   Coding: 191100
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOM.clb
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H02 0090
   Revision: 00002001    Serial number: 10813003966303
   VCID: 75B4E9EE35C22512745-8020
Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H03 0306
   Revision: --------    Serial number: 0000270566160
   Coding: 011D1620DE01459205080000
   VCID: 48CA501A12B0E8FADF3-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 G    HW: 7P0 907 801 G
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1780300222    Dataset Number:             A001
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 372823E66FCE9702A69-8062
   Slave 3:
3 Faults Found:
0004 - Parking Brake Motor; Left
          C10BC 07 [00001000] - Mechanical Failure
          [Aktuator EPB - Blockierter Motor - Links]
             Freeze Frame:
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 62431 km
                    Date: 2023.11.23
                    Time: 12:23:23
                    Voltage: 13.2 V
0040 - Motor for Electronic Parking Brake
          C10E3 29 [00001000] - Signal Implausible
             Freeze Frame:
                    Fault Frequency: 1
                    Reset counter: 66
                    Voltage: 12.4 V
12652544 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
             Freeze Frame:
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 76297 km
                    Date: 2024.07.23
                    Time: 10:38:17
                    Voltage: 7.2 V
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 C    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0120
   Revision: --------    Serial number: -------------- Dataset Number: V03935253MM 0001
   Coding: 012602000B000200
   ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
   ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B00000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B00000
1 Fault Found:
13893632 - Function Restricted due to Insufficient Voltage
          [Funktionseinschraenkung durch Unterspannung -unterer Grenzwert unterschritten]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 76297 km
                    Date: 2024.07.23
                    Time: 10:38:12
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227G$0H5043439
   Coding: 040005010000000003
   VCID: 2616FEA2B8E41E8A0DF-8072
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 7P6 035 764 N    HW: 7P6 035 764 A
   Component: H-BNT-RW      H43 1062
   Revision: --------    Serial number: 605H40H7514297
   Coding: 020A01050040E9EF71300B0E00000003F00001030000000000
   VCID: 44D2442A2E98CC9A33B-8010
   Subsystem 1 - Part No: 8R0 060 884 EG
   Component: ROW 2017  0905
   Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: DU8 SV Touch  H56 0046
   Serial number: VWZ8Z9TGF01RC7
   Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Subsystem 4 - Part No: 8R0 060 961 G
   Component: CD-Database  9040
Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H04 0306
   Revision: --------    Serial number: 0000272333325
   Coding: 011814200001259005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0003
   Serial number: 40000000070527 Dataset Number: V03935251GV 0001
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
   Component: Anhaenger     H20 0160
   Revision: 7C001003    Serial number: 0436412484
   Coding: 0300000202000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_TrailFunctGener2Hella 001005
   ROD: EV_TrailFunctGener2Hella_VW52.rod
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 G    HW: 7P6 907 441 G
   Component: TopView       H09 0115
   Revision: 11001001    Serial number: 82330JG0431538
   Coding: 0100000001000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   VCID: 3D2431CE4DF2BD527C5-8068
1 Fault Found:
9617697 - Function Restricted due to Insufficient Voltage
          [Functional limitation by undervoltage]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 38
                    Reset counter: 27
                    Mileage: 65672 km
                    Date: 2023.12.27
                    Time: 09:32:49
                    Voltage terminal 30: 8.0 V
                    Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 203702135 Dataset Number: 7p0771v____ 0012
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
   Component: TSG HR        H04 0306
   Revision: --------    Serial number: 0000272344461
Address 85: On Board Cam. (J852)       Labels:| 7P6-907-217.clb
   Part No SW: 7P6 907 217 B    HW: 7P6 907 217
   Component: DPC-SG        H27 0035
   Revision: --------    Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
   Coding: E8030000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 392C25DE59DA817250D-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000007070026_3465
Address 8B: Adaptive Cruise 2 (J428)       Labels:| 4H0-907-561.clb
   Part No SW: 7P6 907 541 C    HW: 7P6 907 541
   Coding: 3704010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 002011
   ROD: EV_AdaptCruisContr2VW526_002.rod
   VCID: 3A2E3AD25CDC8A6A597-806E
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107 B    HW: 7P6 907 107
   Component: BV-SG         H34 0035
   Serial number: 005002472802177
   Coding: 0A809F040000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR_002.rod
Address 8F: Pretens. Frt Left (J854)       Labels: 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 C
   Component: RGS-VL        H16 0080
   Dataset Number: 7P0FH1v____ 0010
   Coding: 00660600031F037F00033810594097000000
   Shop #: WSC 00001 790 00001
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313C1DFE81AA4932E8D-8064
Address 90: Pretens. Frt Right (J855)       Labels: 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 C
   Component: RGS-VR        H16 0080
   Dataset Number: 7P0FF1v____ 0010
   Coding: 006606000317037F00033810594097000000
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323E12F284AC722A917-8066
End----------(Elapsed Time: 02:40, VBatt start/end: 12.2V/12.2V)-----------
Discussion starter · #11 ·
Thanks rgh0
Correct I am not a VCDS expert and was not aware of where or how to obtain a history file.
Managed to work it out and it is attached below.
Interpreting it is yet another challenge !
Code:
Saturday,27,July,2024,09:02:20:12603
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
Mileage: 76501   Repair Order:
Control Module Part Number: 7P6 907 530 R
  Component and/or Version: GW-CAN-L-FR-M H15 6055
           Software Coding: 0001037D00
            Work Shop Code: WSC 31414
                      VCID: 47C853261F2EE782DE9-8012
History Data
Record 1/16: No-load voltage underranging
2024-07-24-10:24*00.0*03*06027***
2024-07-23-09:58*00.1*03**
2024-07-23-09:09*18.1*03**
2024-07-22-15:02*24.0*03**
2024-07-21-15:00*24.0*03**
2024-07-20-14:58*21.5*03**
2024-07-18-14:04*18.5*03**
2024-05-16-16:24*00.2*03*00000***
2023-10-14-12:36*00.0*03**
2023-09-11-14:49*00.0*03**
2023-08-13-12:29*00.0*03**
2023-08-12-12:26*00.0*03**
2023-08-12-11:30*00.0*03**
2023-08-11-11:52*00.0*03**
2018-11-04-22:22*15.3*01*00000***
2018-11-04-22:21*15.3*01**
2018-11-04-06:58*24.0*01**
2018-11-03-06:56*24.0*01**
2018-11-02-06:54*24.0*01**
Record 2/16: No-load current overranging
2023-03-02-21:26*0004*033*-00.10*0-0-0-0-0-0*0*03*00043**
2023-03-01-16:43*0005*041*-00.11*0-0-0-0-0-0*0*03**
2023-02-06-20:53*0001*038*-00.11*0-0-0-0-0-0*0*03**
2023-02-04-16:34*0001*036*-00.11*0-0-0-0-0-0*0*03**
2022-07-02-16:00*0002*036*-00.11*0-0-0-0-0-0*0*03**
2022-07-02-12:57*0002*043*-00.10*0-0-0-0-0-0*0*03**
2021-10-21-07:25*0003*052*-00.10*0-0-0-0-0-0*0*03**
2021-10-21-04:49*0003*064*-00.10*0-0-0-0-0-0*0*03**
2021-10-21-00:48*0004*058*-00.10*0-0-0-0-0-0*0*03**
2021-09-22-08:35*0003*047*-00.10*0-0-0-0-0-0*0*03**
Record 3/16: Shut-off stage history
2024-07-23-11:07*1*0*036*005*-13.31*0-0-0-0-0-0*0*0*00.0*00.2**
2024-01-15-08:51*1*0*043*005*-22.95*0-0-0-0-0-0*0*0*00.1*00.3**
2023-03-01-20:43*1*0*062*041*-10.24*0-0-0-0-0-0*0*0*00.0*00.0**
2021-10-21-03:48*1*0*077*058*-10.16*0-0-0-0-0-0*0*0*00.0*00.0**
2021-09-21-21:42*1*0*069*055*-10.34*0-0-0-0-0-0*0*0*00.0*00.1**
2021-09-18-00:00*1*0*074*059*-10.34*0-0-0-0-0-0*0*0*00.0*00.0**
2020-01-10-15:02*3*0*007*000*-12.01*0-0-0-0-0-0*0*0*00.0*00.0**
2020-01-10-15:01*1*0*007*000*-14.18*0-0-0-0-0-0*0*0*00.0*00.0**
2020-01-10-14:58*3*0*008*000*-10.32*0-0-0-0-0-0*0*0*00.0*00.1**
2020-01-10-14:57*2*0*014*000*-31.75*0-0-1-1-0-0*0*0*00.0*00.1**
2020-01-10-14:54*1*0*016*000*-33.98*0-0-1-1-0-0*0*0*00.0*00.0**
2020-01-10-14:52*3*0*017*000*-19.34*0-0-0-0-0-0*0*0*00.0*00.0**
2020-01-10-14:48*1*0*044*006*-30.92*0-0-1-1-0-0*0*0*00.0*00.1**
2019-12-31-12:57*1*0*035*000*-14.24*0-0-0-0-0-0*0*0*00.0*00.0**
2019-12-31-12:44*3*0*038*000*-11.19*0-0-0-0-0-0*0*0*00.0*00.0**
Record 4/16: Battery change history
2020-01-10-15:31*03*110*VAO*381120K0LR*10009*07191*0000*0000*0000**
2020-01-10-15:27*02*110*VAO*381120K0LR*10002*00000*0000*0000*0000**
2017-08-31-23:34*01*110*VAO*VAO3H8E03R*09995*01985*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*10000*00000*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**
Record 5/16: Energy-critical vehicle states
2020-01-10-14:49*-00.35*-04.80*-30.37*11.28*000*08*-04.5*01978*10001*009709*0-0-1-1-0-0*0*00.1*00.1*000.9*03*01*05**
2019-12-31-11:16*-00.05*-00.47*-21.59*11.58*000*07*-08.8*01936*09999*009461*0-0-0-0-0-0*0*00.2*00.3*018.1*05*01*04**
2019-12-19-07:44*-00.03*-00.52*-23.96*11.36*000*07*-11.8*01802*09993*008071*0-0-0-0-0-0*0*00.3*00.4*022.1*07*01*03**
2019-11-26-16:18*+00.00*-19.86*-13.39*11.53*000*05*+00.0*01754*09982*008046*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*02**
2018-06-09-03:42*+00.00*+00.00*-99.99*10.20*000*05*-03.0*00111*09973*000025*0-0-0-0-0-0*0*00.0*00.0*814.0*05*01*01**
Record 6/16: Energy balances (last 20 trips)
2024-07-25-14:58*043*+27*+004.9*00.11**
2024-07-25-13:01*048*+26*+002.6*00.48**
2024-07-25-12:52*041*+25*+001.0*00.06**
2024-07-25-12:35*040*+24*+004.2*00.15**
2024-07-25-12:28*038*+23*+000.3*00.00**
2024-07-25-11:27*044*+23*+000.5*00.01**
2024-07-25-11:03*048*+22*+000.2*00.00**
2024-07-25-10:25*051*+22*+000.5*00.10**
2024-07-25-10:12*052*+22*+000.3*00.13**
2024-07-25-10:09*052*+22*+000.4*00.03**
2024-07-25-09:59*052*+22*+000.6*00.08**
2024-07-25-09:19*056*+21*+003.3*00.48**
2024-07-24-16:58*054*+22*+001.0*00.23**
2024-07-24-10:46*049*+22*+004.1*00.23**
2024-07-24-10:26*045*+21*+000.4*00.01**
2024-07-23-17:12*053*+29*+001.1*00.41**
2024-07-23-15:49*052*+29*+006.6*01.33**
2024-07-23-14:28*035*+26*+001.1*00.21**
2024-07-23-12:17*032*+24*+001.6*00.28**
2024-07-23-11:24*030*+23*+006.9*00.41**
Record 7/16: Energy balances (last 20 standing times)
2024-07-25-13:31*034*-006.7*001.3*00.3*00.2**
2024-07-25-12:57*040*-000.4*000.0*00.0*00.0**
2024-07-25-12:45*039*-000.3*000.1*00.0*00.0**
2024-07-25-12:29*035*-000.6*000.1*00.0*00.0**
2024-07-25-11:29*033*-002.5*000.9*00.1*00.0**
2024-07-25-11:04*044*-001.9*000.3*00.1*00.0**
2024-07-25-10:31*041*-000.6*000.5*00.0*00.0**
2024-07-25-10:21*051*-000.5*000.0*00.0*00.0**
2024-07-25-10:11*051*-000.3*000.0*00.0*00.0**
2024-07-25-10:05*052*-000.4*000.0*00.0*00.0**
2024-07-25-09:48*054*-001.3*000.1*00.0*00.0**
2024-07-24-17:13*043*-002.3*016.0*00.0*00.0**
2024-07-24-11:00*044*-001.1*005.9*00.0*00.0**
2024-07-24-10:27*032*-000.6*000.2*00.0*00.0**
2024-07-23-17:37*041*-006.5*016.6*00.2*00.1**
2024-07-23-17:09*052*-000.4*000.0*00.0*00.0**
2024-07-23-14:41*021*-003.1*001.1*00.4*00.0**
2024-07-23-12:35*023*-000.6*001.8*00.0*00.0**
2024-07-23-11:50*022*-000.5*000.4*00.0*00.0**
2024-07-23-11:17*018*-000.8*000.1*00.0*00.0**
Record 8/16: Battery manipulation (e.g. charging)
2024-07-25-15:30*1*15*00*00*08*06*2000-01-01-00:00*03**
2024-03-31-08:54*4*14*00*00*08*06*2024-03-31-06:23*03**
2023-11-28-09:32*4*14*00*00*07*06*2023-11-28-12:02*03**
2022-12-02-16:15*1*14*00*00*06*06*2000-01-01-00:00*03**
2022-12-02-16:13*1*13*00*00*06*06*2000-01-01-00:00*03**
Record 9/16: Battery aging
2020-02-10-10:53*100*100*086*078*00132*12.60*+23*03*12.70*00003*00000**
2024-07-08-14:04*086*076*058*035*07126*12.20*+18*03*12.70*00340*00000**
2024-06-12-11:01*091*085*059*040*07100*12.20*+18*03*12.70*00337*00000**
2024-05-14-11:42*091*086*058*040*07057*12.20*+21*03*12.70*00335*00000**
2024-04-18-11:33*095*091*074*057*07014*12.40*+29*03*12.70*00333*00000**
2024-03-21-11:32*085*082*064*038*06799*12.30*+18*03*12.70*00323*00000**
2024-02-25-11:07*084*084*070*047*06661*12.40*+21*03*12.70*00315*00000**
2024-01-27-10:29*086*082*069*045*06504*12.40*+17*03*12.70*00305*00000**
2023-12-31-10:04*084*082*070*044*06305*12.40*+16*03*12.70*00294*00000**
2023-12-02-11:06*089*086*069*049*06133*12.40*+19*03*12.70*00284*00000**
2023-11-06-11:05*088*085*069*050*05949*12.40*+19*03*12.70*00272*00000**
2023-10-09-10:20*083*079*067*038*05748*12.30*+10*03*12.70*00262*00000**
Record 10/16: Dynamic energy management
2000-01-01-00:00*0*000.0*0*000.0*0*000.0*00.00**
2000-01-01-00:00*0*0*0*00.00**
2000-01-01-00:00*0*000.0*00.00**
2024-05-16-16:46*99*15.00*14.10*84.30**
2024-04-16-08:44*99*15.00*14.34*39.70**
2024-04-07-13:57*99*15.00*14.44*51.00**
2024-04-06-13:04*99*15.00*14.38*52.90**
2024-04-06-09:56*99*15.00*14.25*70.20**
Record 11/16: Recuperation
2024-07-25-10:25*000*000*000*004*0063*006*00.1*00.7*075*051*075*051*01*00385*00583*00123*01037*01417**
2024-07-25-10:12*000*000*001*008*0001*008*00.0*00.5*076*051*076*052*01**
2024-07-25-10:09*000*000*001*000*0000*002*00.0*00.4*076*052*076*052*01**
2024-07-25-09:59*000*000*003*002*0000*005*00.0*00.7*076*054*077*052*01**
2024-07-25-09:45*000*000*001*001*0029*029*00.0*00.1*070*039*080*056*01**
2024-07-24-16:58*000*000*007*004*0123*014*00.1*01.1*078*045*078*054*01**
2024-07-23-17:12*000*000*019*000*0235*025*00.0*01.1*077*052*078*053*01**
2024-05-17-15:36*000*000*009*007*0179*020*00.1*01.9*076*057*077*058*01**
2024-05-17-15:26*000*000*001*002*0046*004*00.0*00.5*077*058*077*057*01**
2024-05-17-14:54*000*000*012*005*0191*022*00.1*02.4*076*048*078*059*01**
Record 12/16: Start-Stop
2024-07-23-16:16*1*061*037*+28*01*+30.0*+00.3*14.4*1**
2024-07-18-14:37*1*060*034*+18*02*+30.0*+00.4*14.6*1**
2024-07-10-09:54*2*059*025*+18*02*+30.0*+03.6*12.4*1**
2024-07-07-11:06*1*060*037*+18*02*+30.0*+00.6*14.6*1**
2024-06-28-15:16*1*060*039*+20*02*+30.0*+00.7*14.5*1**
00088*00047*00000**
Record 13/16: Sporadic alternator faults
2000-01-01-00:00*0-0-0-0-0*000.0*00000**
2000-01-01-00:00*0-0-0-0-0*000.0**
Record 14/16: Small battery for hybrid vehicle
2000-01-01-00:00*00*---*---*----------*00000*00000**
2000-01-01-00:00*0*00*00*00*00*00**
00000*00000*00000**
2000-01-01-00:00*0-0-0-0-0-0-0-0**
00000*00000*00000*00000*00000*00000*00000*00000**
2000-01-01-00:00*0*000*000*00*00000*00000**
00000*00000*00000**
Record 15/16: Local activ.
2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
Record 16/16: Vehicle energy balance
076501**
00001*00117*04647*00288*00008**
01481*00051*00015*00002**
17711*01537*00125*00012**
01196*01496*00813*01189**
02675*01378*00641**
04884*00317*00068*00010**
01232*00006*00002**
00012*00000*00000**
00007*00000*00000**
00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**
1 - 4 of 13 Posts
