1 - 9 of 9 Posts
I have a stop running gear fault on the dash. The front suspension raises and lowers, the rear is stuck in the highest setting. I have scanned it with VCDS and i get the following codes:
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 H
Component: LUFTFDR.-CDC- 3C3P1 3099
Coding: 0015521
Shop #: WSC 31414 790 00001
VCID: 3878ECA1485DC6811B-5154
1 Fault Found:
01400 - Suspension Level Control
001 - Upper Limit Exceeded
I have some more fault codes but i am unsure if they are related to my fault in question. I have attached the scan.
I have had a search around and i think it could be my rear residual pressure valve but it would be strange for both of them to fail at the same time. I will be getting them checked on Monday.
Discussion Starter · #9 ·
No, did not try to empty the air strut. I took my tablet/vcds but the battery was flat, i tried my car charger but it would not give it enough power. I don't get time during the week as i am at work. I phone my mechanic and i let him know what to do during the day. I will try the output tests on vcds after the compressor has been rebuilt, if it does not fix it.
1 - 9 of 9 Posts
