Is there a way to test the stepper motor if it is still good or has gone bad, like you might your alternator? It is not a cheap part and seems you should be able to have it tested as it also easily removed.
Also, I have read several posts about stepper motor failure related to the system fault workshop warning and it being a common issue. I have also read that the drive shaft and or diffs are also common problems. Along with a long list of many. But, I was wondering if there is any correlation between the stepper motor failure and the later failing?
Thanks club for your amazing support and any feedback.
