Aloha form Hawaii!
I own a 2008 V6 Treg with about 110K miles. About 30k miles ago the amber colored ESP Traction control light came on. When I've been at the VW Dealer for service they've mentioned something about the traction control sensor in the steering column needs to be replaced. I haven't really ever worried about it until a few weeks ago when out of the blue the steering wheel locked up, a warning sound came on and the screen read "Steering Column Lock Workshop." I knew enough to not get it towed to VW and instead rented a Vag-Com, did a little research and was able to unlock the immobilizer. Amazing how with one click of a button everything returned to normal.
It's been about 2 weeks now and there have been no other issues, but I'm thinking the immobilizer was linked to the steering column or the traction control light. Before returning the Vag-Com I ran a scan and here were the results for the ABS section:
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 K HW: 7L0 907 379 K
Component: ESP ALLRAD MK25E1 0302
Revision: 00H53001
Coding: 0004354
Shop #: WSC 31414 790 00001
VCID: 418911111CFB874294-8014
3 Faults Found:
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 56
Mileage: 174102 km
Time Indication: 0
Date: 2018.12.31
Time: 21:20:09
Freeze Frame:
Count: 768
Count: 8449
Count: 293
Count: 5
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 255
Reset counter: 45
Mileage: 158033 km
Time Indication: 0
Date: 2017.06.03
Time: 15:25:01
Freeze Frame:
Count: 128
Count: 12545
Count: 294
Count: 3
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Reset counter: 48
Mileage: 158033 km
Time Indication: 0
Date: 2017.06.03
Time: 16:15:17
Freeze Frame:
Count: 1792
Count: 12545
Count: 292
Count: 3
My initial thought was to look up the part number 7L0 907 379 K, but that appears to be the ABS brake pump, and I kind of doubt that was the issue. What is catching my eye is the third fault 00778 - Steering Angle Sensor (G85) 014 - Defective. I don't know the exact part number for the steering angle sensor, but as I've looked online it seems to be referring to the clock spring in the steering column, which I believe is what the VW dealer spoke about in the past. Before I order this part and take off my steering wheel, I thought I'd open it up the community for feedback. I found a great post on mytreg.com, from somebody with a similar issue, but after replacing the sensor, they finally discovered it was a blown fuse. I went through the fuses, but didn't find any issues.
I'm sure if I have the VW dealer look at it again they'll charge at least $2K to do it, so any help the Treg community can offer would be much appreciated.
Mahalo,
Andy
PS I also suspect the steering angle sensor because the backup camera's hover guide lines disappear when turning the car and the scan for that section reads:
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 C HW: 7L6 907 441 C
Component: J772__Rearview 0021
Revision: 00H13000 Serial number: PA8 J790341
Coding: 0100001
VCID: 356175C15C333BE238-8060
1 Fault Found:
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 174395 km
Time Indication: 0
Date: 2019.01.14
Time: 18:36:01
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Revision: 00H53001
Coding: 0004354
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 56
Mileage: 174102 km
Time Indication: 0
Date: 2018.12.31
Time: 21:20:09
Freeze Frame:
Count: 768
Count: 8449
Count: 293
Count: 5
000 - -
Freeze Frame:
Fault Priority: 2
Reset counter: 45
Mileage: 158033 km
Time Indication: 0
Date: 2017.06.03
Time: 15:25:01
Freeze Frame:
Count: 128
Count: 12545
Count: 294
Count: 3
014 - Defective
Freeze Frame:
Fault Priority: 2
Reset counter: 48
Mileage: 158033 km
Time Indication: 0
Date: 2017.06.03
Time: 16:15:17
Freeze Frame:
Count: 1792
Count: 12545
Count: 292
Count: 3
Mahalo,
Andy
Coding: 0100001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 174395 km
Time Indication: 0
Date: 2019.01.14
Time: 18:36:01
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
