1 - 18 of 18 Posts
Administrator
Since the facelift Touareg (Touareg2, or T2) is being sold in higher numbers, questions regarding VAG-COM coding modifications to these vehicles are increasing.
Unfortunately for Touareg2 owners, there have been substantial changes to the underlying computer network in the vehicle, and most of the modules now communicate solely over the CAN-BUS. This is not unlike the newer Audi's, Jetta's and Rabbits in production today. Gone are the days of base 10 module codings. Say hello to long coding in hexadecimal.
As far as I know, there are no known coding modifications for the Touareg2, nor have I seen much discussion on such modifications. Let's see if we can't change that, or if we can gather any information on the subject that might exist, especially on international sites like Touareg Freunde.
I have found some codes that relate to new modules, including the DRL features, but the results are unknown and possibly untested. We need some brave Touareg2 owners with a new CAN based VAG-COM cable to do some testing. Please post you results and information in this thread.
VAG-COM Links:
VW Touareg (7L - Ross-Tech Wiki)
Ross-Tech: VAG-COM: Touareg / Phaeton Applications
Ross-Tech: VAG-COM Tour: Recode
Internation Touareg Forums:
Touareg-Freunde, das Volkswagen Touareg Forum im Netz
Administrator
Discussion Starter #2
Here are the long coding option for the central electronics module
Coding
Note: Use long coding helper.
  • Byte 00 Bit 0 Daytime Running Lights
  • Byte 00 Bit 1 Country/Area North America
  • Byte 00 Bit 2
  • Byte 00 Bit 3 Rear Fog Disabled in Off-Road Mode
  • Byte 00 Bit 4
  • Byte 00 Bit 5 Front Fog Lights
  • Byte 00 Bit 6 Rear Fog Lights
  • Byte 00 Bit 7 High Beam with Assistance Driving Light
  • Byte 01
  • Byte 02 Bit 0 Halogen Headlights (Rest of World)
  • Byte 02 Bit 1 Halogen Headlights (North America)
  • Byte 02 Bit 2 Xenon Headlights (Rest of World)
  • Byte 02 Bit 3 Xenon Headlights (North America)
  • Byte 02 Bit 4
  • Byte 02 Bit 5
  • Byte 02 Bit 6
  • Byte 02 Bit 7
  • Byte 03
  • Byte 04 Bit 0 Assistance Driving Light
  • Byte 04 Bit 1 Coming-Home
  • Byte 04 Bit 2 Garage/Cinema Light
  • Byte 04 Bit 3 Comfort/Tip Blinking
  • Byte 04 Bit 4 Emergency Brake Blinking
  • Byte 04 Bit 5 Comfort Interior Lightning
  • Byte 04 Bit 6
  • Byte 04 Bit 7
  • Byte 05 Bit 0
  • Byte 05 Bit 1 Hydraulic Nozzles for Headlight Washers
  • Byte 05 Bit 2 Electric Fuel Pump for FSI Engines
  • Byte 05 Bit 3 Electric Fuel Pump for Gasoline Engines (NOT FSI)
  • Byte 05 Bit 4 Electric Fuel Pump for Auxiliary Heating
  • Byte 05 Bit 5 Wake-Up Function (for Air Suspension)
  • Byte 05 Bit 6 Anti-Theft Protected Headlights
  • Byte 05 Bit 7
  • Byte 06 Bit 0 Second Battery Network
  • Byte 06 Bit 1 Second Battery
  • Byte 06 Bit 2 Generator Port
  • Byte 06 Bit 3 Seat Heating
  • Byte 06 Bit 4 Load Management
  • Byte 06 Bit 5 Load Consumer
  • Byte 06 Bit 6 Generator Port Idle
  • Byte 06 Bit 7
  • Byte 07
  • Byte 08
  • Byte 09
  • Byte 10
  • Byte 11
  • Byte 12
  • Byte 13
  • Byte 14
  • Byte 15
Hey TREGinginCO, get that T2 back from Michigan before they crush it so we can do some "experimentation" on it!
(OFF-Topic) I could see you guys playing mad scientist up there on it now!
While you're at it, strip off the air suspension and ship it to Vegas, and I'll send back my steel suspension parts! :D
(/Back on topic)
Too bad we didn't have time to hook up the Vag-Com while we had it. It may have given some insight into what's going on behind the scenes.
Also, on Ross-Tech's site, it mentions that the newer CAN-capable cables are required for Touaregs manufactured after Novemver 2006. Is this only for the face-lifted models that were being sold overseas, or was it for ALL Touaregs (old and new face) after that time?
Matt
We did determine at the rally the cable I got is usable on the T2? I hope it is since I got it at such a good deal and would hate to have to buy another one when I get my 09 TDI V6. ;)
Administrator
Yeti, I don't remember the exact cable you had. We needed a Hex+CAN cable. My cable is only a HEX (K-Line) cable.
Administrator
Well, then what in the hell was stopping you guys?!? We coul'd have had that T2 vagged six ways to Sunday before we gave it back to VW.
(/Back on topic)
Matt
From what I can gather (Mainly from Ross Tech) at least some of the '07 production run (Production date after Nov. 30, 2006) has what they call "Touareg Mark II" internals. These can be identified by the body code, which (I think) are characters 7-9 of the VIN. Mark I models are "7LA" and Mark II models are "7L6". I wonder if this started when the FSI V-8 was introduced, wasn't this a mid-year addition (IIRC, you could not get a '07 with a V-8 early in the model year). Anyway my '07 V-8 FSI has a VIN that has the 7L6 code, s/n (last 6 digits of the VIN) of 023xxx. The engine code is "BAR", btw.
It's the Mark II cars that require the HEX-USB+CAN cable (or the SER version) for full functionality. I gather that the older cables work on some modules.
T-Man
Administrator
I've got the FSI V8 but my VIN is 021xxx so I'm guessing I have the old internals. I do have the HEX-USB+CAN cable since my jetta runs on CAN bus.
Administrator
Discussion Starter #10
Nick, can you confirm this with a scan sometime?
Administrator
Body code is 7L6 with a build date of week 29/2006 ('07 model year)..both these taken from the stampings on the body behind the gas flap. Ran a VAG-COM scan and a number of components are 7L6, and a few are 7L0. What's interesting is the "Chassis Type" comes up as 7L. Not sure if this is different in earlier/later models...engine comes up as 7L0 910 560, not sure what code it translates into.
Administrator
Discussion Starter #13
Nick, can you post a copy of your scan results?
Umm, beer and just general lazyness at the rally. :drunk::mrgreen:
Administrator
For your viewing pleasure: I'm guessing the fault relating to voltage are due to it sitting in airport parking lots for a week at a time:
Saturday,22,September,2007,00:59:43:51332
VAG-COM Version: Release 704.1
Data version: 20070723
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
Address 01: Engine Labels: None
Part No SW: 7L0 910 560 F HW: 7L0 907 560
Component: 4.2l V8/4V 0010
Coding: 04210009590F0960
Shop #: WSC 31414
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09D-927-750.LBL
Part No SW: 09D 927 750 CR HW: 09D 927 750 CR
Component: AL 750 6A 0941
Coding: 0012392
Shop #: WSC 31414
Address 03: ABS Brakes Labels: 7L0-907-379.LBL
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014338
Shop #: WSC 31414
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 135 B HW: 5WK 485 16
Component: Kessy 6840
Coding: 0000232
Shop #: WSC 31414
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 08: Auto HVAC Labels: None
Part No: 7L6 907 040 T
Component: CLIMAtronic R/L 4222
Coding: 0000030
Shop #: WSC 31414
Address 09: Cent. Elect. Labels: 7L6-937-049.LBL
Part No: 7L6 937 049 M
Component: 3003
Coding: 0100572
Shop #: WSC 31414
2 Faults Found:
00907 - Intervention load Management
000 - - - Intermittent
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 3D0-909-601.LBL
Part No: 3D0 909 601 E
Component: 0W Airbag 8.4E+ H10 0952
Coding: 0012375
Shop #: WSC 31414
Address 16: Steering wheel Labels: 7L6-953-549.LBL
Part No: 7L6 953 549 J
Component: Lenksäulenmodul 3401
Coding: 0010231
Shop #: WSC 31414
Address 17: Instruments Labels: 7L6-920-xxx-17.LBL
Part No: 7L6 920 871 M
Component: KOMBIINSTRUMENT RB8 2111
Coding: 0005331
Shop #: WSC 31414
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 31414
Address 1C: Position Sensing Labels: 7L6-919-879.LBL
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0119
Address 29: Left Light Labels: None
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000002
Shop #: WSC 31414
Address 36: Seat Mem. Drvr Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0702
Coding: 0000000
Shop #: WSC 00000
Address 39: Right Light Labels: None
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000002
Shop #: WSC 31414
Address 46: Central Conv. Labels: None
Part No: 7L0 959 933 H
Component: YM HSG 0400
Coding: 0000085
Shop #: WSC 93245
Part No: 7L0 959 701 G
Component: Tuersteuergeraet FS 0201
Part No: 7L0 959 702 G
Component: Tuersteuergeraet BF 0201
Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 56: Radio Labels: None
Part No: 7L6 035 180 H
Component: Radio DE2 0003
Coding: 0001405
Shop #: WSC 31414
1 Fault Found:
00878 - Connection to Speaker Front Left
011 - Open Circuit - Intermittent
Address 68: Wiper Electr. Labels: None
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414
Part No: 1K0 955 559 AE
Component: RLS 280806 014 1201
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: None
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
Shop #: WSC 31414
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.LBL
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
End --------------------------------------------------------------------------------------------------
Humm. Mine also has 29/2006 as the build date. Maybe the Nov 30, 2006 date was the start of production for the T2 and we do have Mk I internals?
Administrator
hmmmm, not sure but good question.......I haven't had too much VAG time with either of my vehicles but the long coding on the Jetta is very very different than the coding on the Touareg.
As an aside I am so glad I bought this '07, it seems to have all the bugs worked out of it and has been so reliable. Hasn't had a single issue.
My God,it's full of stars
BTW the long conding, is the bit ordering little or big endian? Meaning where is the most significant bit, left or right? TIA
siberian
1 - 18 of 18 Posts
