So here is my stalling story. A couple of weeks ago, leaving the office, it took longer than normal to crank, then started dying after 30 or so seconds. Started back up easily though. Repeated that about 8-10 times until I finally called AAA and had it towed home.
Searched all the related posts and all pointed to fuel pump(s). I decided to check electircal and output of pumps. Electrical checked out. Fuel pressure on system was between 50 and 60 PSI. Left pump supplied 80ml of fuel in 15 seconds while right pump supplied 90ml of fuel in 15 seconds. All seemed OK, so I put everything back together and it ran fine for 50-100 miles or around town driving.
Had a minor battery issue after not driving it for a week or so, took care of that and then the 30 second stall started up again. Decided to change the fuel filter on the left side since it was obvious neither access point had never been tampered with. Good thing as the fuel that was draining out of the filter appeared that it had fine particulates in it.
Fired it up afterwards and it ran great at idle and revving it up for over a minute or so, then gradually started dying (much slower than previously). Repeated this 3-4 times with same result. I then unplugged the left pump, started it up and had the same results. Plugged the left pump back in, unplugged the right pump, started it and have the same result. Each time it fires up right away and runs good for a good minute.
This has me stumped. Trying to understand if it is indeed a pump and if so which one, or if there is something else going on.
