1 - 1 of 1 Posts
Hello.
I have a V10 Treg, and since I mended the rusted eccentric at the rear some squeaking is happening when the wheels are moving up and down. I think I have tracked the source, it should be the upper rear arm's inner side bush on both side. Somebody knows the torques for these bolts? Another issue, but I don't know if it is related, that the car tends to steer off sometimes. I suspect it is not the front that does this. The difference is not that great, about 15 degrees on the steering wheel, but it is frightening when nothing is on the road, yet something changes. It might also be connected to the noises. The chassis adjustment was done a month ago, but the rear right and the front left wheels are 10mils more down than other side, that will be solved as soon as I fetch a usable laptop. Can you see some connection in these issues?
Thanks a lot lads, nice day!
1 - 1 of 1 Posts
