1 - 6 of 6 Posts
Just need your input guys on this issue.
About two week ago my My16 V6 TDI has developed this high pitch squeaking noise, first it started while gently braking at low speed, so I called VW Sydney City and they told me it's brake dust on brakes and all I need to do is to use high pressure gun and blast them with water. This unfortunately did not work as the noise is still there but now the car is squeaking even while driving. High pitch noise sometimes louder, sometimes quieter.
It doesn't start squeaking straight away, I need to drive it a bit for it to start happening but even then its interment....
If I did not have air suspension I would think its coming from suspensions but that is not the case I think
Anyway I'm booked in for test drive VW technician in two weeks, to demonstrate the issue but I'm just worried that they might tell me its common for it to squeak(brake dust etc) and tell me to live with it (read on VW forums that this is quite common)
If that happens what would be my best defense?
I don't really want to life with squeaking car.
If they say that have them show you on another Treg on the lot... because that would be bull..since yours is a 16 that should be easy.
Should be found and fixed. Could be something simple like a foreign object where it shouldn't be (like a rock wedged inbetween the rotor and splash guard...heck one time I got a wire up in there from the road...made a nasty strange noise).
2015 R Line V8
had same thing with my R32. Thought it may have been a wheel bearing.
Up on the hoist, wheel off, caliper off...offending 'stone' removed.
No more noise :)
Learner
I would say its probably a stone, pebble in the brakes/rotor
1 - 6 of 6 Posts
