Hi all,
Firstly thanks to all that posted on my last question it was really appreciated.
Right now down to the pig, every time i go over a speed bump then accelerate away i get a rythmic clunking which sounds like somthing has been pushed out of line from under the front, then as i accelerate away the noise gradually dissapears as if its centralized again, I have noticed this once whilst reversing but have never heard it from just simply driving without speed bumps. The mightly Treg has had a new prop carrier bearing, Near side drive shaft, both front wheel bearings, disks and pads and on off side rear wheel bearing, so im kinda hoping that this dispells alot off possible faults. Secondly ive also noticed im seeing the ESP light up now and again at slow speeds on cornering which could be related i suppose. Ive plugged my VAG scanner in and its not picking up any faults, so im stuck
. Im looking to sell now to upgrade to a 3.0 altitude so i kinda need to sort it before i can pass it on, the Treg is a 2.5Tdi R5 2005 if this helps.
If someone could please shine a ray of light on this annoying clunk id be over the moon.
Slaky
Slaky
