Hi All
been using the forum for info and help for a little while but never posted, have to say the info on here is great!
I have a 2.5 Touareg 2004 which recently had to have its ecu replaced due to water damage! I was wondering where the ecu is placed the water from rain etc drops onto the casing is this right just afraid the same issue will occur again?
I also have an issue with my driver side headlight as in the indicator is always showing as not working but if I go and push the headlight or give it a slight knock it works again for a short while then stops, not sure if it's loose or what but has anyone experienced this?
Also are all touaregs supposed to have the ability to display mpg info etc, I have an option in my settings to set metrics n stuff but can't actually see how to show up d mpg I only get the option to show time or journey time?
Thanks in advance!
Thanks in advance!
