I picked up this fully loaded T2 V8 w/ Air in the Salsa Red color. Yes, its a factory color and the original owner ordered it.
If you google this Touareg color, the one you will see is exactly the one I have, so it's why I say I have the only one in the country? Anyways I have few issues.
1) I have these two codes. The first one, I'm planning on replacing the sensor and pick up a HPFP from an Q7 at the salvage yard.
2) For the second code, take a look at the picture of intake manifold. The 2 intake manifold drive unit (circled in Red) don't move at all, even when you rev the engine. So the flaps are not opening or closing. I read somewhere on the Q7 forum that they open at a higher rpm. They just seem stuck. Can they be cleaned or something? There is a Q7 V8 at the salvage yard that I'm planning on taking the part from
3) So the Touareg drives just fine and goes through all gears smoothly and does not seem to lack power. But once the engine hit 3000 rpm, it acts like its starving, like lacking fuel or something. When you floor it at speed to get going or take over another vehicle, as long as the downshift is below 3K rpm and it will move as usual/normal and no issues. BUT whenever you floor it and the downshift happens at 3K rpm, the Touareg just does not move, does not go anywhere, lacking power as if something is blocking or stopping it from moving forward or something. You can drive however you want, staying below 3K, everything would be fine, but going hard or full throttle to the point it hits 3K cause hesitation or a sign of lack power.
I wonder if my intake manifold issue and even fuel pump causing this? Any ideas, thoughts? Thank you.
Address 01: Engine Labels: 079-907-560-BAR.clb
Control Module Part Number: 7L0 907 560 E HW: 7L0 907 560 E
Component and/or Version: 4.2l V8/4V 0030
Software Coding: 04210009590F0560
Work Shop Code: WSC 31414 790 00001
VCID: 3365AACB513561130E-515A
5 Faults Found:
008854 - Fuel Pressure Regulator Valve (N276)
P2296 - 001 - Short to Plus - MIL ON
008200 - Intake Manifold Flap; Bank 1
P2008 - 004 - Electrical Malfunction - MIL ON
005241 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - - MIL ON
008585 - Bank 2; System too Lean at Idle
P2189 - 004 - - MIL ON
5 Faults Found:
