I drive my TDI Touareg about once every 3-5 months, and the battery is just barely able to start. Last time I hooked up a charger to it, I put in about 50Ah. Decided to add a solar panel to keep it topped off. I have a cable going though the panel to hold it in place, and prevent it from easily being stolen. I put a hole in the cover for the cable, and crimped a grommet to prevent tearing. Should be able to put in about 1-1.5 Ah per day. The charge controller has bluetooth, so I can monitor the battery voltage without having to take the cover off. I stuck the bluetooth transmitter under the plastic cowl at the base of the windshield.
