I own a 2011 TDI Lux with 19" 265/50R19 wheels. Live in Atlanta, GA and am going skiing in North Carolina with my family in a few weeks. While snow is a non issue in Atlanta I've been to NC ski slopes in past and was deeply troubled by lack of traction in snow and ice on steep mountain roads. I saw numerous other vehicles stranded and wrecked. Very, very scary and dangerous if conditions are bad (which they often are).
So... now I have an expensive, supposedly super-capable AWD SUV vehicle seemingly perfect for my upcoming ski trip. I researched snow chains for days on the Internet. Checked the owners manual and called VW-- of course all of that was 100% useless as VW is always useless in providing info to owners. Officially VW says no snow chains except for 17" and 18 wheels (17" wheels on a Touareg?). If you do use chains, one page in owners manual says put them only on front, other page says put on all 4 wheels. Which is it?
FYI, I give VW an "F" on the quality of the owner's manual which is filled with useless cr*p including out on date references to features not on the current US models. Painful to read- mainly filled with redundant legal disclaimers written by VW attorneys. Anyway...
Best solution seemed to be super low profile SCC cables. Model I needed for my wheels was SZ435 Super Z-6. I had high hopes this would work. Alas, I went to my tire store today and had them test fit while Treg was on lift and manually rotated the wheels (and also lowered to ground too in case compressed suspension made a difference). It was a close call but NO THEY DO NOT FIT. More precisely, they do fit the wheels/tires but at least one of the interior connectors rubs against the upper A arm and comes scary close to a variety of critical and delicate brake components/wires/tubes etc which could be destroyed. All of this is virtually hidden from sight as it all is contained on the inside of the wheel/tires assembly. You need to put your Treg on a lift to see any of this. What you see on outside and at circumference of wheel is OK. If these low profile chains/cables do not work I believe no other chain/cable system would-- the Treg simply has clearances inside the wheel that are too tight.
I'm pretty p*ssed at VW that snow chains cannot be used on a vehicle of this type with factory 19" wheels. I appreciate the sophisticated suspension and handling of this otherwise fine vehicle but come on... seems they owe us a wheel/suspension design that allows 3rd party snow chains/cables or VW should design and sell their own temporary snow traction solution for the Touareg.
I'm going to try the Auto Sock. I've seen some good comments on those but am skeptical. They cannot be used on dry roads.
I assume all 2011 and later Touaregs with 19" or 20" wheels will have same problem. If anyone has a better solution than Auto Socks please post.
Thanx,
Thanx,
