I drove my 2013 V8 TDI R line to the snow on Friday night at Mt Hotham in Victoria last weekend for some skiing for the first time since I got it and Covid closures of ski resorts ended
Temperatures got down to around -3 C to -5C over night and when I left on Sunday there was a 20cm diameter red coolant spot in the snow under the car inside the LH front wheel and behind the axle roughly in line with the edge of the inner wheel arch panel
There was no measurable coolant loss in the header tank at the time and no further loss in the last few days having returned to Melbourne and 5 to 10 degrees C overnight minimum temps.
My presumption is that a hose to pipe connection in the area of the leak was the cause due to the alloy pipe shrinking in the cold weather and the spring clip clamp not maintaining sufficient compression on the hose resulting in a small leak. The car has the 4 zone heating / cooling and I believe there are coolant pipes that run back into the cabin rear heater system in the area of the leak behind the plastic inner wheel arch panels.
Has anyone else experienced similar issues ?? Heading up to the snow again in a few weeks and will take some spare coolant and if it occurs again I will investigate the potential source further.
cheers
Rohan
cheers
Rohan
