1 - 11 of 11 Posts
Searched for mirror. No luck.
Both mirrors barely move with the control. When I pull the mirror the assy is very stiff. Feels like it's the motors or the gears, not the socket. Any advise on lubricating those to let them move?
Thanks, Tim
White lithium grease?? I'd try greasing the metal "ears" behind the mirror first. Does the motor move easily with the mirror detached? If so, the ears need the grease.
The motor does not move with mirror removed. I have to help it. Needs disassembly to lube it seems.
Multiple v10tdi owner
(3)2004 V10tdi’s
The motors on the 08's seem to be a problem area. I had an issue with mine and after many attempts to locate the problem I just replaced both motors. In hind sight I would have done that first as the time spent was far more than the cost of the replacement parts.
I'll do this today. Thank you for the heads up. This will save time and effort. I appreciate the heads up.
Tim
If you can move the motor arms manually, the gear mechanism has broken. There are two slip rings inside the motor housing. I "welded" them together with my soldering iron set at 550F. Caution: VERY noxious fumes!!!
Or you can replace the motors. Last I looked, around $80-$90 USD on eBay.
Sweet. VW quoted me $485 each for the motors. Nuts.
(3)2004 V10tdi’s
That's not right...I have memory mirrors and that was more expensive and they were $115.00 each from my dealer parts department . The other style was about $90.00. That was a few weeks ago and online pricing will be less.
I bought one at the Stealership for $160 before I saw the bay ones. That's when I got motivated to repair the broken ones! LOL! I did put the new replacement in the passenger side, as it dips in reverse and thus gets more usage.
Discussion Starter #10
Strong VW in SLC. Verified twice. Must be quoting me a entire mirror with cover. I asked for motor only. I'll just go eBay since that's the service I got. Thanks for the reply.
(3)2004 V10tdi’s
7L6-959-577 $74.88 w/o memory mirrors
7L6-959-577A $102.24 with memory mirrors
Same part left and right side
Found on line at:
Vwpartsvortex.com
Not a recommendation, just source of part numbers and price.
I paid about $10.00 more locally but they are very good so it's worth the few dollars more to me.
1 - 11 of 11 Posts
