shaking when braking
12487 Views 11 Replies 9 Participants Last post by  noobytoogy
I have a 2012 TDI Lux with 35,000 miles on it that has started shaking when I brake, but only if the disks are hot. So, on highway at 70, put on the brakes and no shake. This weekend coming down a 10 mile hill in Vermont, the brakes get warm/hot (not riding the brakes but from intermittent application) and the treg starts shaking when I apply the brakes, the steering wheel moving back and forth at least an inch, the whole vehicle vibrating. When brakes are off, it rides turbine smooth at any speed.
Still in warrantee, but dealer says warped disks not covered. Articles linked to this forum say no such thing as warped disks, it's pad material bonded to rotor, you need to sand them.
Anyone else have experience with this? Any solutions? thanks
1 - 12 of 12 Posts
You need to replace rotors when you replace pads...Are you on your second set of pads?
This would be my approach to your problem:
First get the run out checked on your discs/rotors with a dial indicator.
Here's a random video about run out to give you an idea. It's quite a good one as there are problems with brand new repalcements!
if they're good, then I'd check the disc/rotor thickness to see if they are still within wear tolerances.
If both pass the test, I'd consider putting in a new set of pads but in reality I think new discs/rotors, pads and brake wear sensors would be the way to go at 35K.
All of this can be done any competent brake workshop who will be cheaper than a VW dealer.
On long mountain descents I use Tiptronic to hold a lower gear for engine braking rather than rely solely on the brakes especially if there's lots of twists and turns as this sets the car up better for corners as well.
The other things is if I have heated the brakes up well, if I have to stop for a lights or a railway crossing or traffic, then I use the parking brake rather than leave my foot on the brake pedal. A] that's annoying for anyone behind! and B] there is no hot spot building on the discs/rotors where the pads are clamped on by my foot!
There are lots of threads on here about which brakes to use - personally I'd go with OEM on a car so young.
See less See more
This is hard to recommend anything in your situation. I hope your dealer is the good one - in this case you have a chance to exploit warranty. If not – you might try to find better VW dealer first and if unsuccessful, pay out of pocket for brake pads and (most likely) disks replacement. The replacement of both done at a VW dealership would run somewhere ~$1200+. The “warped disks” diagnosis is nothing, but your dealer BS. Here is a bit of reading on the subject which you might find not very amusing:
http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
I got my brake pads and disks warranty-replaced at ~16K for the notorious squeaking noise reason (when backing out of the garage in reverse on a cold and dump morning). Three complaints were recognized as sufficient reason for the dealer to request replacement approval by the VWoA. You have vibration and they do not wish to accept it as a reason for warranty replacement. I can only guess that this is because you are too close to 40K miles which, as I was told, is “normal” mileage/time to replace brake pads.
See less See more
You might want to see if you have thrown a wheel weight, or rotate the tires front-rear to see if the problem changes before going after the brakes. If the problem stays with pulsation and the steering is still wobbly, then it is likely a glazing problem of the rotors. Truly "warped" rotors are super uncommon, although this is the general term that most people use to describe the problem.
it would be caused by pad material being unevenly bonded to the rotor. You must have gotten your brakes very hot at some point , more than a few times. Unfortunately it will not be possible to simply sand the offending glaze off. I have tried in vain on previous vehicles. In my case , I live near the top of an extreme hill and because of speed limits I have to ride the brakes almost all the way down (residential).
On my previous vehicle (2003 4runner) I was replacing rotors every 18-24 months because of pedal pulsation. It was as cheap to replace the rotors as turning rotors, which never fixes the root cause anyway. Even paying for premium rotors and pads made little difference, it was the weight of the vehicle and the conditions needed to stop a couple times a day every day.
See less See more
sounds an awful lot like warped rotors..a runout meter should show this in a few seconds. If so fight for a warranty claim or bite the bullet and replace the rotors.
Excellent write up!, and also welcome to the site, I see your a new member.
Not just warped rotors but small thickness variations can cause the vibration symptoms. The steering wheel shake is caused by increased brake drag first on one front wheel, then the other. Solution is to replace the rotors - especially the front.
Classic symptom that you report.
I can seeing needing new brake parts at 35k miles, particularly if you find yourself slamming around the roads near Boston (Go Sox). No experience yet on T3 brake longevity here, but as good as they are, Touareg brakes will wear out.
Maintenance item. Carry On.
I am having the same issues with my '04 --- had the brakes changed not too long ago, but had tires changed this past summer. Maybe a weight flew off a rim? I need to get it checked out before the rattling damages my car.
Touareg wheels pick up a lot of crud on the inside, unseen part of the wheel.
Centrifugal force normally evens the crud out so the wheel stays in balance.
We had a lot of deep standing water just before Christmas due to exceptionally heavy rain and 80-90 mph winds resulting in Tommy Treg doing quite a bit of wading.
On the first high speed run on Christmas Day I was getting some steering wheel shake so, on reaching my destination, I used their high pressure hose to clean all the cack out form behind the wheels before sitting down to lunch.
The run back home was vibration free.
This has happened to me before where deep water wading obviously loosens and then dislodges a chunk of the crud that was keeping the wheel in balance.
See less See more
1 - 12 of 12 Posts
