Serpentine belt snapped
6K views 40 replies 7 participants last post by  Mexglx
New ownership to a Touareg continues to be interesting. Was driving and power steering went and battery light came on. Pulled over and had a quick look in the engine bay - the serpentine belt was clearly at fault.
Having gotten towed home and managed to inspect in daylight, it seems that something has seized and caused the belt to bake and then snap - plenty of baked on deposits on the various pulleys.
I’m tempted to think it’s the air conditioning compressor, but what’s the best troubleshooting (asking here before I do anything).
Can I just grab and rotate everything to see if it will move?
Definitely the aircon compressor (bottom right as looking at the engine from the front) as everything else turns ok (some of the tensioner pulleys are a bit noisy). Getting a different garage to come and have a look shortly.
Will assume I’ll need to replace the aircon compressor, new pulleys and tensioner, and a new belt.
Access doesn’t look too bad.
Is there anything worth doing at the same time?
I had the previous garage quote to do the timing belt (although the main one is a chain, apparently there’s a belt for the fuelpump?) but I’m going to bin them off and get this other lot to do that.
(will upload scan when I’ve got back to my desk)
#10 · (Edited)
Code:
Friday,28,July,2023,09:40:42:18311
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVGZZZ7LZ7D056850   License Plate: J109216
Mileage: 167490km-104073mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ7D056850   Mileage: 167490km-104073miles
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 7L0 907 401 C    HW:
   Component: 3.0L V6TDI  G000AG  0040
   Revision: --H03---    Serial number: VWZ3Z0F3541769
   Coding: 0011775
   Shop #: WSC 31414 790 00001
   VCID: 2B031552CF1148228A9-5184
   VINID: 9E65EAAAA1DCA87500146205006A0C60B2
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 GG    HW: 09D 927 750 GG
   Component: AL 750 6A           1015
   Revision: 00H61000    Serial number:
   Coding: 0004200
   VCID: 79AFFF1A75CD2AB2485-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0014594
   VCID: 3D272B0A2165D69224D-5184
Address 05: Acc/Start Auth.        Labels: 3D0-909-13x-05.lbl
   Part No SW: 3D0 909 137 D    HW: 5WK 485 05
   Component: 20 Kessy            6840
   Revision: 68406418    Serial number: VWZ3Z0F3541769
   Coding: 0147688
   VCID: 2809EA5EDEE7633A67B-5184
   Component: ELV                 XXXX
1 Fault Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
            011 - Open Circuit
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 T
   Component: CLIMAtronic R/L     4222
   Coding: 0000530
   VCID: 41DF57FA5D9DB272405-5184
3 Faults Found:
02101 - Side Vent Motor (V262)
            000 - -
00710 - Defroster Flap Positioning Motor (V107)
            000 - -
01592 - Air Quality Sensor (G238)
            014 - Defective - Intermittent
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 M
   Component:                     3003
   Coding: 0120036
   VCID: 46D544E674B3954A757-5184
1 Fault Found:
00907 - Intervention load Management
            000 - -
Address 15: Airbags        Labels: 3D0-909-601.lbl
   Part No: 3D0 909 601 F
   Component: 0C Airbag 8.4E+ H11 1151
   Coding: 0012355
   VCID: 2615E466D4F3754A557-5184
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 H
   Component: Lenksäulenmodul     3401
   Coding: 0010031
   VCID: 44D15EEE428FA75A6B3-5184
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 981 M
   Component: KOMBIINSTRUMENT RB8 3211
   Coding: 0006411
   VCID: 43D35DF24781A062529-5184
1 Fault Found:
00464 - Control Module with Display for Radio and Navigation (J503)
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 815 071 D
   Component: Standheizung E1MAC
   Coding: 0000000
   Shop #: WSC 00000 000 00000
   VCID: 33330D32172110E2C29-5184
1 Fault Found:
02251 - Heater Unit Locked
            000 - -
Address 19: CAN Gateway        Labels: 6N0-909-901-19.clb
   Part No: 6N0 909 901
   Component: Gateway K<>CAN      0101
   Coding: 0000006
   VCID: 70B9C23E26B76BFAFFB-5184
1 Fault Found:
Address 22: AWD        Labels: None
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0119
   VCID: 7F5B11026BE90482761-5160
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 H
   Component: LUFTFDR.-CDC- 3C3P1 3099
   Coding: 0015521
   VCID: 38293A1E0E47F3BAF7B-5184
1 Fault Found:
00668 - Supply Voltage Terminal 30
            009 - Open or Short to Ground
Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
   Part No: 7L6 919 887 H
   Component:      Navigation     0030
   Coding: 0000111
   VCID: 4BC375D26FD16822AA9-5184
Address 46: Central Conv.        Labels: 7L0-959-933.clb
   Part No: 7L0 959 933 H
   Component: YN HSG              0400
   Coding: 0000069
   VCID: 41DF57FA5D9DB272405-4B1E
   Subsystem 1 - Part No: 7L0 959 701 L
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 L
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
   Subsystem 5 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
   Subsystem 6 - Part No: 7L6 951 171 B
   Component:    Innenraumsensor  0020
2 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
            009 - Open or Short to Ground - Intermittent
00988 - Lamp for Brake Light; Right (M10)
Address 55: Headlight Range        Labels: 7L6-907-357.lbl
   Part No SW: 7L6 907 357     HW: 7L6 907 357
   Component: AFS-Steuergeraet    0003
   Revision:   H09       Serial number:
   Coding: 0000008
   VCID: 78A9FA1E4EC733BA37B-5184
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000034
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000034
Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
   Part No: 7L6 035 186 D
   Component:        Radio        0030
   Coding: 0016452
   VCID: 34310E2E122F17DADB3-5184
Address 57: TV Tuner        Labels: 7L6-919-146.clb
   Part No: 7L6 919 146 D
   Component: TV Tuner        H04 1111
   Coding: 0000030
   VCID: 3B2325123F71D8A21A9-5184
2 Faults Found:
00863 - Antenna 1 for TV (R55)
            011 - Open Circuit - Intermittent
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 L
   Component: Front Wiper         4027
   Coding: 0000336
   Shop #: WSC 31414 790 376833
   Component: RLS nicht vorhanden
   Coding: 00000000
   Shop #: WSC 00000
Address 76: Park Assist        Labels: Redir Fail!
   Part No: 7L0 919 283 F
   Component: 0D Einparkhilfe     1107
   VCID: 392F3F1A354DEAB2085-5184
1 Fault Found:
00435 - Front Right Inner Parking Aid Sensor (G333)
Address 77: Telephone        Labels: Redir Fail!
   Part No SW: 7L6 035 729 H    HW: 7L6 035 729 H
   Component: FSE_275x        H21 0030
   Revision: 00000001    Serial number: 00000000534719
   Coding: 0000311
1 Fault Found:
02503 - Output Wire to Radio
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 149
                    Time Indication: 15
End----------(Elapsed Time: 08:11, VBatt start/end: 12.0V/12.0V)-----------
Theres obviously a load of Intervention load Management errors but I'd expect that from the fact it hasn't got the alternator going and assume shut down a bunch of things.
Battery is on charge to make sure it doesn't die.
Can't see anything particular about the compressor dying though...
Yes it appears to be a mechanical issue not seen in the electronics. Could be a siezing pulley and the pulley with the most damage is the most likely to be the cause if this is the case. How old was belt and its wear versus the wear limits ? Has it ever been changed during the 100k miles on the car ? if not, its past its expected life time IMHO
That's from my gen not his... if you guys really want to bust balls....
Regardless of what any manual says, he didn't change it it time... there's no "schedule" for how long a belt will last when a component fails
Also, can you someone define "usual conditions" for me?
RTFM. Apparently usual is not dusty. Lol. Seriously, what does it say on page 28?
New ownership to a Touareg continues to be interesting. Was driving and power steering went and battery light came on. Pulled over and had a quick look in the engine bay - the serpentine belt was clearly at fault. Having gotten towed home and managed to inspect in daylight, it seems that something has seized and caused the belt to bake and then snap - plenty of baked on deposits on the various pulleys. I’m tempted to think it’s the air conditioning compressor, but what’s the best troubleshooting (asking here before I do anything). Can I just grab and rotate everything to see if it will move? View attachment 259359 View attachment 259363 View attachment 259361 View attachment 259362 View attachment 259364 View attachment 259360 View attachment 259358
Ok I have a 2014 TDI and had the same problem with the serpentine belt going out and taking all the pillows with it. If they had replaced the belt at regular intervals like they should it would have been a 200.00 job but instead it turned into a 1500.00 job. When I asked the service why they don’t replace the belt at 50 or 100 k he looked at me with a straight face and said they do a visual inspection at every service . A lot of good that did me.
What @SaVAGeSoot is arguing with you about is that, more than likely your pulley's bearings were already getting worn and took out the belt. The belt, while robust, is not going to harm the pulleys. The belt doesn't stop unless a pulley stopped. If a belt breaks and wraps around things, the crank may yank on it but the belt will get shredded before it ever hurts a pulley. If you have a unique failure mode proving otherwise, I would actually be interested to see it. I don't mind learning about new and unique failure modes. I just had an auxiliary water pump push water into the electrical wiring affecting my air temp, hood latch, and airbag crash sensors. Anything is possible.
#36 ·
My pulleys were ok except one that was a bit noisy, but because the belt had clearly started baking once the aircon compressor seized, it left baked on parts of belt on every pulley. Main ones can be cleaned but as everything’s off, I might as well get the tensioner ones swapped. But I suppose even regular belt changes wouldn’t have stopped this happening (due to the aircon compressor seizing).
#38 ·
Further expanding on what @Mexglx clearly had more patience than me to spell out, the belt only rotates in conjunction with all the pulleys (rollers that either drive it - like the crank one, or that are driven by it - like the alternator) and all the idlers (simple rollers including the sprung one - aka tensioner). If any of of the driven components (compressor, pumps, alternator) wear out and start providing more resistance than can be overcome by the friction provided by the belt onto the respective pulley, then, the belt essentially starts doing a burnout on said roller. Idlers\tensioners with noisy bearings are screaming for help and are giving you an audible notice that frictional forces have increased and that you're about to have a bad day. Ignore the signs and heat + wear accelerates, and eventually they seize up completely, or just enough to start damaging the belt at an accelerated rate. The belt is a purely a victim of these kinds of degradations, as well as a wear component itself, where it's effected by time in service and it looses its optimal properties.
A belt that fails, will typically take out other surrounding stuff as it wraps around it and rips things apart, or suddenly stops something like another component from spinning, but if said component is a simple idler, it wouldn't hurt it.
Thanks for the explanation. It makes sense. Now I’m dealing with a whine between 45and 55. I was told it was the rear differential. I had a guy replace but still had the whine so I had him put the old diff back in .So 1300.00 later I still have the whine so he wants to replace the drive shaft. I asked what happens if that doesn’t work . His reply was if that doesn’t we csn replace the transfer case. Are you kidding me? I guess it’s a matter of if he runs out of things to replace or so run out of money. Which ever comes first😂
