1 - 3 of 3 Posts
The lumbar support module in driver's electromic seats stopped working...Other electronic movements are ok. Any idea where the fault may be? Is lumbar support inflated by compressed air or by a electric motor ? Does it have separate fuse?
_____________________________________
15/2/04 Lumbar support mechanism has a separate 10A fuse underneath the seat (not in the fuse box), parallel to the floor, above the battery box. I found the fuse on the floor between cables. The fuse fitted loosely in the fuse holder and it is probably prone to fall off if the car hits a big bump or ditch.
Any idea on how to make the fuse stay in its place? Will chewing gum void the warranty?
Lumbar support
If all of the electric movements of the seat stopped, check the fuse. If it's just the lumbar it will probably need a technician.
1 - 3 of 3 Posts
