1 - 2 of 2 Posts
Used PIE adapter to get pipe in satellite or other audio (Ipod, etc) via a standard miniplug jack into your VW or Audi as listed below. Description below from the manufacturer. Does not come with audio cable (you can get that in any radio shack or online easily).
Worked fine in my Touareg, just don't have the car anymore.
$20 + shipping
PIE Precision Interface Electronics XM5-VW02 EnfigCarStereo.com
The P.I.E. - XM5-VW02 will allow direct audio input of the Power & audio Interface - MyFi, Tau, Pioneer Airware, Roady XT, Pioneer Express & S50(needs special cable)through the CD changer port of the OEM VW radio for optimal sound quality. The built in 5-volt power supply of the PIE XM5-VW02 powers the unit directly, elimenating the need to use the external cigarette lighter adapter.
  • Direct wired Audio Input via 3.5mm headphone jack.
  • Hard wired 5V power supply.
  • Does not affect the CD player or CD changer if it is part of the radio in the dash.
  • For cars equipped with factory satellite radio you must use the satellite pass through or disconnect it.
  • Cannot keep the CD changer in the trunk.
  • Cannot keep the CD changer in the glove box.
  • Cannot keep the CD changer in the center counsel.
  • Will not work with the Phatnoise Phatbox
AudiA3
2005-2006
All cars with the new navigation radios that have the memory card slots.A4
2005-2006
All cars with the new navigation radios that have the memory card slots.VolkswagenGolf GTi R322006
All Radios (if you have factory satellite radio you will need the pass-thru)2003-2005
All Radios2002
Only the radios with a CD/Cassette radio.Jetta2005.5
All Radios2002
Only the radios with a CD/Cassette radio.Passat2006
All Radios2002
Only the radios with a CD/Cassette radio.Touareg2004-2006
1 - 2 of 2 Posts
