1 - 2 of 2 Posts
I am thinking to install running boards. What r the pros and cons? I heard need to remove something underneath..
Not sure where you are from, but its usually good manners to introduce your self when joining a forum?
Your location and vehicle model also helps other members assist you.
But yes the covers running along the sills needs to come off. I made some aluminum plates to replace them.
the Ali covers bolt to the running board via unistrut nuts and to treadserts in the chassis.
If you don't do dirt roads it may not be an issue but the air suspension pump and air con pipes will be exposed otherwise.
1 - 2 of 2 Posts
