Ok so here’s an update I have, I noticed something strange on my generic obd2 scanner, it says that my sensors are reversed. I went to look into the evap purge solenoid code it said it can come up from 5% difference in o2 sensor values. Unplugged bank 1 sensor 1, on the live data it showed I dropped bank 2 sensor 1, swapped them car ran like garbage, looked on the older ones and saw that something was up with the positioning of my o2 sensors were in the wrong spots, took them em
All out and swapped them to the correct positions, now I am left with a much smoother idle, but still getting these codes.
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 65 6D 72
VIN: WVGFF9BP9CD001289 Mileage: 284543km-176806miles
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
47-Sound System -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
Address 01: Engine (J623-CGRA) Labels: None
Part No SW: 03H 906 023 AG HW: 03H 907 309 E
Component: 3,6 FSI ULEV2 H16 1324
Revision: M7H16--- CVN: 6F53DA74
Coding: 002A0012432600000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM36FSI01103H906023AG 001003
ROD: EV_ECM36FSI01103H906023AG.rod
VCID: 67DD0E9B9E6DDDAEE2-8032
VINID: 9E65D65894A025350000108824AA473FD2
1 Fault Found:
11227 - Oxygen (Lambda) Sensor Signals Swapped
P0040 00 [11101101] - B1-S1 / B2-S1
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 284539 km
Date: 2024.12.08
Time: 14:32:43
Engine RPM: 735.00 /min
Normed load value: 25.5 %
Vehicle speed: 0 km/h
Coolant temperature: 85 �C
Intake air temperature: 24 �C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.583 V
Unlearning counter according OBD: 40
Heated oxygen sensor bank 1: sensor 1: resistance: 301.72 Ohm
Heated oxygen sensor bank 1: sensor 1: activation: 36.545 %
Outside air temperature via CAN: 12.8 �C
Oxygen sensor 1 bank 1 ceramic temp: 779.36 �C
Heated oxygen sensor bank 2: sensor 1: resistance: 299.69 Ohm
Oxygen sensor B1: sensor 1: voltage: 0.713 V
Oxygen_sensor_bank_2_sensor_1_voltage: 1.812 V
Readiness: 1100 0101
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 A HW: 0C8 927 750 A
Component: AL1000 AISIN 001 1870
Serial number: CVN: 95DE0D17
Coding: 001368
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_VW52.rod
VCID: 2A5BB7AF4DFF20C63D-807E
No fault code found.
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 K HW: 7P0 907 379 A
Component: MK25A H36 0418
Revision: -------- Serial number: 416510010EC010 Dataset Number: 7P0012v____ 7P13
Coding: 5B7613C349242554DAF6C89B92DBA4407700
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 4581E413C4A1EFBE30-8010
1 Fault Found:
336397 - Databus
U1123 00 [01001000] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 236
Mileage: 284420 km
Date: 2024.12.03
Time: 18:55:22
Standard Freeze Frame Dynamic: 00 49 00 00 00 00 00 00 01 00 01 20 01
Part No SW: 4H0 907 064 BK HW: 4H0 907 064 BK
Component: BCM2 2.0 H31 0330
Revision: 00002001
Coding: 0D860000000000000000
VCID: 73E56ACBD2B5210E4E-8026
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000125979016
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BA HW: 7P6 907 040 BA
Component: Klima 2 Zonen H20 1203
Coding: 4686200A80
VCID: 74E769D7DFBB263657-8020
1 Fault Found:
0402 - Coolant Circulation Pump
B10D0 13 [00001001] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 284420 km
Date: 2024.12.02
Time: 21:13:58
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0100
Revision: 15012002 Serial number: 00000001117132
Coding: 26001012973C5D010020180300005D0C431C460882010261000000020000
VCID: 6BD572AB8A85F9CE86-803E
Component: WWS 110604 31 0020
Serial number: 90243400110624145301
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10194583
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000002206110371
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0L9T06
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H05 0021
Revision: -------- Serial number: 28291116783189
Coding: 100501
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 428BFF0FD58FD88615-8016
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag02D H05 0023
Revision: -------- Serial number: 003JX003852U Dataset Number: 7P6003v____ 0789
Coding: 000000000000000000000000000000003244
ASAM Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 408FF507DB83CA9603-8014
Seat occupied recognition:
Serial number: 5850000R1132403JSY
Serial number: 3575LRB405V0JR9K18OC
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB405L0JR9K70EY
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515RRB40570KSEG988Q
Passenger side rear thorax airbag crash sensor:
Serial number: 3525RRB40570KSEG8OTK
Serial number: 3555NRB405N0J2N0FPQ6
Serial number: 3565NRB405P0J2N0K8P$
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815KFN0006A
Coding: 000C15
VCID: 387F9DE78B538256BB-806C
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0090612
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 M HW: 7P6 920 980 M
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658290611592012
Coding: 8B7732022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 4683E31FF9A7E4A639-8012
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000181820
Coding: 0021032600
GVL: FB4F40455D73000000
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 387F9DE783538256BB-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650726809
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000006239918
Coding: 00581B0000004001000001010101202020202121202020
VCID: 3467A9D7973B663697-8060
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000117293521
Coding: 011D17205E00453005080000
VCID: 4487F917C79BD6B627-8010
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0151572857
Coding: 0106123A28B9509580B00620010000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 147111812
Subsystem 2 - Part No: 1K0 951 605 C
Subsystem 3 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H07 0006
Serial number: WOO1235248%
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H07 0006
Serial number: WOO12395385
Coding: 191100
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811000731603
VCID: 75E154D3DCC13F3E60-8020
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000117387730
VCID: 3B7582EBBA65A94E56-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: A11603000E0 Dataset Number: A001
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 366393DF89477426A9-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0008
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CF741F7F7EB6E761F-8028
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 130000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H51 0076
Revision: AB001007 Serial number: 156F/0B7514819
Coding: 020007010000000001
VCID: 1F4D567B0EBDD56E5A-804A
Part No SW: 7P6 035 664 B HW: 7P6 035 664
Component: H-BN-NA H44 0319
Revision: -------- Serial number: 445FY0B7515830
Coding: 020200050040E1ED41020B0E00000003F0000101
VCID: 377D9EDB864D8D2EB2-8062
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H24 0045
Serial number: VWZ8Z9L29007K9
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000117500261
Coding: 011C17200000253005080000
VCID: 3A7B87EFB55F90464D-806E
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000034607 Dataset Number: 7P6096v____ 0016
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3F8DF6FBA67DB56E7A-806A
2 Faults Found:
8397314 - Front Right TPMS Sensor
C1051 31 [00001001] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 248
Mileage: 279833 km
Date: 2024.07.22
Time: 21:10:15
Vehicle speed: 68 km/h
Outside temperature: 25.5 �C
Reception level antenna 1: 720 mV
Offset level antenna 1: 690 mV
8397826 - Rear Right TPMS Sensor
C1053 31 [00001001] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 122
Mileage: 282960 km
Date: 2024.10.12
Time: 16:57:43
Vehicle speed: 78 km/h
Outside temperature: 25 �C
Reception level antenna 1: 750 mV
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 166100150 Dataset Number: 7p0771v____ 0009
Coding: 0533314002
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000117501209
1 Fault Found:
02123 - Door Warning Light / Entry Light
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 188
Mileage: 284410 km
Time Indication: 0
Date: 2024.12.01
Time: 19:38:45
