Carbon buildup is a thing, especially on direct injected diesels, and has been discussed all over the internet.
EGR deletes and other approaches can sometimes reduce the frequency of physical cleaning requirement.
Thanks everyone for your contributions
The problem was diagnosed by VW dealer as being faulty injectors – 3 of the 6 and quoted in excess of AUD$8500 to fix the problem. I sourced replacement Bosch injectors myself – approximately AUD$400 each and had a specialist diesel service centre replace them, believing VW were way over the top in their quote. The injectors were replaced and it made no difference. Upon further investigation by the independant diesel specialists it was discovered that the entire inlet manifold was ‘sooted’ up, with the throttle body being barely able to work – see pic previously posted. They cleaned what they could – cost AUD$1000 – and made these recommendations:
- The entire manifold system required removal and cleaning up and
- Install a ‘catch can’ to prevent the build-up in the future
- Spend the extra on only using premium quality diesel fuel and filters
I removed and again cleaned what I could and the only thing remaining is the inlet manifold, which is very difficult to remove for a non VW trained home mechanic. Though not tested, they felt that there was nothing wrong with the old injectors, but fitted the new ones anyway.
The catch can has been installed – there is a Provent kit in Australia designed specifically for the Touareg – and it now runs exclusively on premium low sulphur diesel fuel. The end result is that it runs nicely with better fuel consumption. A side story is the stop-start system has now recommenced working. There is still a bit of a sulphur smell but I think this will probably disappear when I get the inlet manifold cleaned properly by my local mechanic, who did his apprenticeship with VW.
So my advice is this:
- Don’t take your car to a VW dealership – instead go to a specialist diesel service centre
- Remove and thoroughly clean what you can of the entire inlet/emission control system
- Install a quality ‘catch-can’ – everyone take notice of this – do it from new
- Use premium quality diesel fuel
- Use genuine air, oil and fuel filters
- Only replace the injectors if you are advised to by a specialist diesel service, not VW.
- After this experience, it is highly unlikely that my car will ever be taken to a VW dealership in the future.
Good luck, Treg friends.
