Rotten egg smell
9.6K views 13 replies 10 participants last post by  matthew@f
We have a real bad smell in the Treg lately, the likes of rotten egg. Its there at startup, then goes away and back every time you stop. The smell seems NOT to be coming from the vents - strange!
The cabin AC filter is brand new, all intakes are free from leaves etc. and the condensation discharge work fine.
Any ideas will be appreciated.
If you are driving a petrol fueled vehicle (unleaded) then manufacturers frequently add a 'perfume' to the fuel in order that the exhaust fumes can be identified by persons being subjected to them. Helps to prevent gassing/poisoning/death etc. Your description of the smell is identical with the above. Nothing you can do about it other than ensure your exhaust doesn't have a leak in it allowing fumes to enter into vehicle. Such fumes actually contain Carbon Monoxide and sufficient exposure WILL cause death.
I can honestly say that this is one of the most ridiculous things I have ever heard...
If this was the case, can you imagine how bad the world would smell????
It's probably a bad cat dude....
voortregger - I have the same smell started on Monday. Really bad when you start the car. I ran over to a friend who works on European cars. He did not have time to totally diagnose but he thinks it is the battery going bad. It's under the driver seat and that would explain the smell... hmmmmm.....
nitromed, I have seen posts reporting that the smell could be sulfide from the battery overcharging.
Mine is a lot better now. I have put in a tank of the best (Chevron) and was wondering if the fresh gas could be responsible for the improvement.
Just a pity the battery is so hard to access, testing would also tell us something.
My battery is now 4 years old and still perform like new. Some warn that the battery can explode!!
I would also look at what your fuel supplier is pumping and whether he is meeting the EPA low-sulfur refinement gasoline requirements. gasolines with a higher sulfur content (rotten egg smell) will reduce the ability of your catalytic converter to perform properly.
you may also want to try a different brand of gasoline/additive package first and see if that takes away the smell
likely rubbish high sulphur fuel you bought somewhere, don't sweat it
