1541 - 1560 of 1575 Posts
2012 Touareg Sport with Nave package.
Do I just extract the Zip file from the Mega site for 0711 directly to the SD card or does it need to be in specific file/folder format?
I checked my version last night and I'm at 0319. I extracted the Zip file directly to an exFAT formatted SD card (exFAT was the only option I had for formatting) but I want to make sure the format of the SD card and the file structure is correct before I attempt an update and screw something up.
It must be FAT32 to be recognised by RNS (use a FAT 32 Utility).
It shall be decompressed in the SD root.
For EU FW HN+_EU_VW_K0821 trere are two folders in the SD Roo and the file metainfo2.txt :
  • 1
  • 2
metainfo2.txt
When the red screen appears the situation is bad. The shudtdown timeout shall be interrupted via terminal serial link to the DVD box.
See attached doc.
I was able to install the SD card with the K0711 firmware and it updated so the unit is back to life!!!
I just pushed in the SD card and it simply updated by itself.
I
It you press PHONE + SETUP again it will get you out of the setup menu. You are correct in that '0319' is your current software version. It would not surprise me if the HD Radio Fix didn't change the major version number, but I'm not an expert on how VW does their software releases.
mine reads the same as your photo shows and i am trying to update maps. Did you end up making any changes?
Thank you
  • Do I just extract the Zip file from the Mega site for 0711 directly to the SD card or does it need to be in specific file/folder format?
    Did you just extract it to the sd card?
  • What did you end up doing?
Just follow the instructions exactly. You extract it to an SD card of a specific size thats been formatted to exFAT explicitly.
Okay.... Need some help.... I have downloaded the update file, extracted it onto the SD Card formatted as instructed. Insert SD Card into Infotainment unit and get an error. I have tried both SD1 and SD2 withe the same results. I have not burned a CD yet but that is my next step as soon as I can find a blank disc.
You didn't follow an instruction somewhere. Either the SD card is too large or you didn't format it to the proper media format, exFAT
SD Card is 64GB. I made sure the format was correct so that was not the issue. Can you point me back to the correct instructions please?
SD card cannot be larger than 32gb
Np let us know how it goes
I don't think the adapter should matter.
You're positive it's converted to exFAT?
Did you Unpack the files into the directories exactly as instructions said?
I am positive the format is exFAT. I am not sure about unpacking as the instructions said. Please send me the post number for the instructions if possible. I have been searching but there are 78 pages to read all the way through.
Lol I don't remember what page that information is on, I'd guess within the first 10 though
