1 - 6 of 6 Posts
I came across a page that details the voice commands available on the RNS510 in other VW models such as the Passat, Golf, GTI, Tiguan. The voice commands are quite extensive, yet in my 2010 Touareg with the same stereo/nav system, all I can do with voice commands is dial phone numbers. Is there a vagcom option to enable full voice commands?
VWVortex.com - Complete list of voice commands and voice menu structure
Here is the complete list of voice commands and the voice menu structure according to me. If there is anything I missed let me know. Items in brackets are user dependent based on your phone book entry.
Call [John Smith at Home]
Dial number
Redial
Music
Play
Stop
Pause
Previous track
Next track
Further options
Read phone book
[Say a name]
Call
Change
Reset name
Next entry
Previous entry
Read all
Call history
Received calls
Call
Missed calls
Call
Dialed numbers
Call
Settings
Short dialog
Long dialog
Bluetooth
Bluetooth visibility
Change PIN
Reset factory defaults
Additional words...
Yes
No
Continue
Cancel
Help
and
Map
Zoom Out
Zoom In
*Change Map Type
2D
3D
Traffic
*Setup Scale
"one mile"
"seven hundreed feet"
"zero point twenty-five miles"
etc.
Split Screen
compass
position map
GPS viewer
Radio
Preset [1]
FM Band
SAT Band
Station List
Frequency [nine one point five]
Channel [alt nation]
NAVIGATION
Enter new destination
City Center
Place
Address
Home
[any pre-recorded voice tag you made]
Remaining Distance
Time of Arrival
Stop Route Guidance
Do they really exist?
That's only for units with software above 2660. North American RNS 510 software tops out at 1142 for Touaregs. We're beat.
Why can't we install past 1142? Someone must be able to modify newer FW to work in Touaregs. What happens when you try flashing newer FW? Does it brick the unit or will it just not install?
Must be a HW thing...but it be cool if it was a FW fix. Sign me up!
NA RNS 510 had slightly different hardware. The FW only went to 1142 for our units. VWoA only recognized and installed one level past the base firmware. The other firmwares had to be found via other means.
1 - 6 of 6 Posts
