1 - 2 of 2 Posts
If my Treg sits for a couple hours or more, it has issues with tracking an accurate location on the map. Sometimes it’s off by a half mile, sometimes it’s several miles off.
When I check to see how many satellites it’s locked on to, it says 0/16. Turning the system off and and doing the hard reset button sequence has no effect. I have driven 30 min in a clear area with no change.
Only thing that seems to correct it is of I shut the engine down and then immediately restart the engine it, then it will immediately connect to satellites and corrects its position on the screen.
Anyone run into this and have any insight? I have virtually never had the Nav map screen up in two years until the last month so I have no clue if this is a recent thing or if it’s always been like that.
I have firmware P0739 and NAR 6.14.2 Maps.
LSIII
This means that moist has entered the gps antenna on the roof and ruined it. Change the antenna, problem goes away. But it isn´t cheap. I guess you need to fork out about $550 to get it done.
1 - 2 of 2 Posts
