21 - 40 of 42 Posts
Discussion Starter · #21 ·
Seems it hasnt been reset to original settings.
One thing that can surely cause this is the mismatch of green setting and CAN gateway. Both must be matched as it was originally.
Any idea on how to do this?
I do remember that I was fiddling with some parameters in the green menu a while back but I don't exactly remember where I was.
Sent from my Pixel 2 XL using Tapatalk
· Learner
What all is checked in your installation list in can gateway
· Premium Member
I would contact the person that "fixed" it for you, and send them the log that you posted and see if they can help.
In the meantime check the fiber optic cables and make sure that they are clean and seated properly
Discussion Starter · #27 ·
I did. I sent him the scan log and he told me that it has nothing to do with what he did.
For a more elaborate story please follow this link:
https://r.tapatalk.com/shareLink?ur...share_tid=283693&share_fid=91021&share_type=t
How do I check the fiber optic cables?
Cheers.
· Learner
Seems something hasnt been set right.
Nonetheless, if you have vcds then go into CAN gateway module then click on installation list and see what all is checked.
There would be two Sound Sytems for example, the right one has to be checked that matches the setup with the unit
Discussion Starter · #29 ·
Singh, what I've noticed it was there were 2 Radio Control Module (56). And they were both enabled. I'll go back home and try either one to see if something changes.
Cheers.
· Learner
There lies your problem, only one should be checked.
Do that and you should be right
Reactions: trdltly
· Learner
Good that its all finally sorted, no probs, thats why this makes a great forum
Radio 56
Hi defishinsea. Were you able to "check" the radio module 56 in OBDEleven?? I tried to do it and experienced the same problem as you (intermittent sound coming from right speakers only). I really need to recode module 56 to enable dynaudio profile (see tip in this forum, it's supposed to make a huge difference in sound quality)... But I cannot do it (reports that it can not contact radio module 56)
Discussion Starter · #35 ·
Hi there,
Couldn't do it in OBDEleven, but I was successful using a Ross Tech VAGCom cable. And YES I enabled the Dynaudio profile. I don't wanna leave my car anymore...
Hi pcote, how did you resolve the intermittent sound from right speakers only issue? I just got the exactly same issue as you after obdeleven scans. Thanks!
21 - 40 of 42 Posts
